588,100 active members*
5,251 visitors online*
    Oct 2005
    378
    New Grizzly G0619 Arrives
    Last week I decided to order a G0619 from Grizzly. The shipping was fast leaving their warehouse in Missouri the next day. Anytime I order a piece of machinery I always a have that fear that the truckers will have their way with it before it makes it to my shop.
    I went today to pick up the machine at the trucking terminal. When I first saw the crate I thought my worst nightmare had come true. The pallet had lost part of the bottom support and one side had completely separated from the enclosure.
    When I looked inside I did'nt know what to expect but to my surprise everything was intact and in perfect condition. I was surprised to see the manual and accessory box just laying inside not attached or stapled to anything. One bolt was missing from the base. Close one! I had to dissasemble the rest of the crate to tie it down.
    I have a Sharp 3 axis knee mill and purchased the G0619 for manual use to do those quick small jobs. It is time consuming to have to boot up the CNC, and home all 3 axis to drill a couple of holes or mill an edge square. I intend to install a DRO and power feeds for the X and Z axis. I will post some more pics once I get the machine set up and I will give a review.
    Anybody have suggestions for a Z power feed?
    Magma-joe
    Attached Thumbnails Attached Thumbnails Grizzly Crate 1.jpg   Crate 2.jpg   Crate 3.jpg   Crate 4.jpg
    Mar 2008
    3655
    Hi Joe. Congratulations on buying a fine mill!
    TEARDOWN AND PREP GUIDE. You don't HAVE to disassemble the spindle bearings:
    http://www.arceurotrade.co.uk/projec...on%20Guide.pdf
    MY SX3 TEARDOWN PICS:
    http://crevicereamer.com/Page_28.html
    CR.
    Too many PMs. Email me to my name plus At A O L dot com.
    Oct 2005
    378
    Crevice Reamer,
    Thanks for the reply. I must say your web site is a wealth of information. I looked at it numerous times when I was deciding which machine to buy. It must have taken a bit of time to build the site. I do appreciate all the info!
    I have been cleaning the machine and and did the spindle break in. I saw your tip about removing the chuck guard and taping the wires. Excellent idea!
    Once I finish I will post some first impressions of the SX3.
    Magma-joe
    Mar 2008
    3655
    Thanks Joe. I still have much more to do on the site.
    Don't forget to either remove the quill DRO, (With power cord disconnected) or insulate between it and the circuit board behind it. If the moving metal DRO shorts against the board, then all of your spindle motor electronics get fried.
    CR.
  1. Grizzly G0619 Sx3 spindle bearings replacement
    By flashbang in forum Benchtop Machines
    Last Post: 03-20-2013, 05:19 PM
  2. GRIZZLY G0619 IN THE ALBQUERQUE AREA?
    By ricksigler in forum Want To Buy...Need help!
    Last Post: 06-23-2009, 12:02 AM
  3. Seig SX3 = Grizzly G0619 = Shop Fox M1111
    By blacksmith99 in forum Benchtop Machines
    Last Post: 01-04-2008, 12:46 AM
  4. NEW 3016FX arrives tomorrow.
    By elaganis in forum Fadal
    Last Post: 05-24-2007, 07:43 PM
  5. HF 8x12 arrives at 2:00 today
    By antichip in forum Mini Lathe
    Last Post: 03-07-2007, 06:01 AM
