Originally Posted by
ChrisJ
Looking for a good remedy to remove surface rust and the rust stain that is underneath the rust spot on cast iron.
I am going to try a brass brush with some solvent (gas, kerosene or other) but I figured I would ask the group here first. I am hoping a brass brush will not scratch the cast iron since some of the spots are on a smooth area of cast iron.
Your suggestions please.
Chris
If gasoline doesn't work, try ether. Be sure to smoke while you are using it. :-)
Gasoline is good for running cars. And reasonably safe. But it should NEVER be used as a cleaner, solvent, for washing your hands, etc. It should never be stored indoors.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
