588,053 active members*
4,287 visitors online*
Page 7 of 8 5678
Results 121 to 140 of 150
  1. #121
    Jul 2006
    143
    I have a rev5 board. It has a sig and Vgrd terminal. The sig is connected to A1N and the Vgrd is connected to Com.
    If I disconnect one of the wires from the output relay and give mach3 a m03s1000, the board will not fault and I get a voltage of about 3vdc across sig and Vgrd.
    i_r_
  2. #122
    Jul 2006
    143
    Got frustrated with the spindle speed issue, so I just wired it up to turn on and am using a pot to manually set the speed. I'll revisit the issue at a latter date. All axis but the rotary table are working, I need to get the power connection for that board,(burned the other one up).
    I'm going to pretty some things up and then post some pictures of it.
    I want to thank you all for dragging my big butt through this whole project!!!!
    i_r_machinist
    aka
    Kerry Bullard, Dublin Texas
  3. #123
    Sep 2006
    300
    Way to go I_R.
    I'll be looking forward to the pics. Can you make a video of it running?
    :banana::banana::wee:
    JAckal
  4. #124
    Jul 2006
    143
    I looked just like that marshmellow guy dancing around in my shop!
    I'll have to take a shorter video today because I can't upload one I have.
    http://bullyztoyz.smugmug.com/Machin...38522141_fi5X2
    I have a picture of it running here.
    haveing fun!
    i_r_
  5. #125
    Sep 2006
    300
    Man ,that looks good!!!
    It seems like forever away for me, but I'll get there. I just have to start first.
    JAckal
  6. #126
    Jul 2006
    143
    Talking
    Video loaded! Its the next icon over on the smugmug link.
    I wouldn't hesitate to start, as long as Larry,Al,Bob, and Kieth are around!
    I had a little problem with my y encoder this morning. The ground wire had broken off at the bottom of the pin. I'll play with ramping up feeds and rapids soon.
    Mach3 is almost too easy to run.
    Haveing fun
    i_r_machinist
    PS. The way I started was to disconnect power, drink six adult beverages, then rip out the control! With no way back, the only path is forward!
  7. #127
    Sep 2006
    300
    Kerry,
    That is great!!!! I'm glad to see it running. It's motivating for me.
    I also have a little cheat help, too. On another thread where I asked about setting up Vipers, a guy named freak_brain < "Allen" started replying. He has the exact machine (almost) that I have. He said that he would give me his Viper setting and Mach 3 settings, too. It might not be EXACT for my machine, but it would be a good starting point for fine tuning.
    Here is the link where Allen comes in.
    http://www.cnczone.com/forums/showthread.php?t=106639
    If this works out ok for me, I know where there is a Wells Index cnc with the kwik switch spindle, that needs retro. Last time I asked he wanted a gold mine for it, though.
    Keep posting new stuff.
    JAckal :cheers:
  8. #128
    Jul 2006
    143
    Got my waylube wired up last night. Now I need to get my power drawbar working. I have a Blackand decker model 2214 120v ac/dc impact wrench that has 4 wires coming off of it. I need to find a wiring diagram. Will hunt later today but have a high profile job to machine first.
    http://bullyztoyz.smugmug.com/Machin...78090126_KeaVa
    have fun
    i_r_
  9. #129
    Sep 2006
    300
    I_R_,
    Are you using any of the Mach brains? I've been looking at those. They are pretty slick.
    JAckal
    Everything is bio-degradable, if you run over it enough times with the lawnmower.
  10. #130
    Nov 2006
    69
    here is a break down of parts for the impact http://www.acetoolrepair.com/parts-b...-type-100.html
    I have a Dewalt for my impact driver.
  11. #131
    Jul 2006
    143
    I found the parts list, but not the wiring diagram. Still looking.
    Haven't played with mach system yet. Did read part of the manual. Looks interesting.
    have fun
    i_r_
  12. #132
    Jul 2006
    143
    Had a little problem with my y encoder last night. I was running a fairlly long program and I noticed the y was not repeating position. It was an engraving with the z stepping down on multiple passes. It looked like it drifted off by about .03". Then on the next pass it was about .1 off so I stopped it. Part didn't move.
    I opened the control and it was hot inside the cabnet. I didn't feel the motor to see if it was hot. I'll try to get my cabnet fans running tonight and try it again.
    i_r_
  13. #133
    Sep 2006
    300
    i_r_,
    Sounds like you are chugging right along.
    JAckal
  14. #134
    Jul 2006
    143
    I ran another long program last night. The Y axis is drifting. Its not the heat in the control cabnet and the motor is warm but not hot. I lost about .2" in 3000 lines of code. I'm not familiar with Mach3. Could this be backlash adding up?
    i_r_
  15. #135
    Dec 2003
    24220
    Backlash does not, or should not add up or increase as according to the number of moves, it only happens once and is reversed everytime the axis reverses.
    If the error is incremental it is usually axis scaling.
    Al.
    Albert E.
  16. #136
    Jul 2006
    143
    I put a 6' grounding rod in behind the machine and grounded the body of the machine to it. Looks like that fixed it. Cut my first metal parts last night. 2 hrs cycle time with no errors.
    I'm going to get on the mach3 yahoo group to learn more about it.
    thanks to all!
    i_r_machinist
    PS. Anyone have a good plasma table design? I'm in the market for another project!
  17. #137
    Sep 2006
    300
    Kerry,
    Glad you figured that out. Are you running a laptop to control the machine?
    JAckal
  18. #138
    Feb 2007
    969
    Mach 3 doesn't like Laptops with the powerdown and sleep modes.
    Your better with a solid desktop with just the basics. Dell or HP are excellent and you should be able to get one in a used computer store for $100-200. Stay away from IBM, their Bios sucks.
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
  19. #139
    Sep 2006
    300
    Larry,
    That's what I've always heard and will do. A few guys are using laptops, but it is sort of hit & miss on which ones will work. I don't want to gamble it.
    Those HP small form factor desktop computers are about $50 plus shipping (fleabay). They have everything but the operating system. 1.8GHZ + processors 512M memory, 40 gig hard drive, etc.
    We have 2 of them now for office work, surfing, and gaming. They are pretty fast, but probably even faster when stripped down. I'll try one of them first for the mach 3, before I buy another one.
    JAckal
  20. #140
    Jul 2006
    143
    Larry,
    What connector do you use for the power in and out of the Viper drives. I need to buy one for my forth axis and Radioshack doesn't have anything that looks like it.
    i_r_
    Jackal
    I'm still stumbling around in Mach3, functional but not fluent.
Page 7 of 8 5678
  1. Another Sharnoa CNC Retrofit
    By MetalCNCing in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2017, 10:13 AM
  2. 1987 Sharnoa SDC-80D Z axis drift problem
    By eric14779 in forum Servo Motors / Drives
    Last Post: 03-10-2011, 02:31 PM
  3. 1987 Sharnoa SDC-80D Z axis parts diagram of section drawing
    Last Post: 02-14-2011, 03:16 PM
  4. BP S1 Z axis retrofit
    By CNC OT in forum Bridgeport / Hardinge Mills
    Last Post: 09-05-2007, 09:42 PM
