587,229 active members*
5,551 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 078 NUMBER NOT FOUND with M100 ON FANUC 18M
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Your home made macro works then, did the manuals help ?
    dung_ninhbinh
    Contact your local Doosan CNC dept,
    DOOSAN MECATEC Co Ltd.
    DOOSAN VINA (CPE PLANT)
    DUNG QUAT ECONOMIC ZONE
    BINH THUAN BIN SON
    QUANGNGAI PROVINCE, VIETNAM
    TEL: 84 553 618 900
    FAX: 84 553 618 955
    They need to know
    1. Machine Model number
    2. Machine Serial number
    3. Control Model
    Tell them that you have lost all 9000 macros and please help to get new ones
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
  2. #22
    2932
    Mystic,
    Now I'm confused. I thought dung_ninhbinh had an Anderson router and FrankCNC had a Daewoo ACE H-100. Did I miss something?
    Dave
  3. #23
    Jul 2010
    thank you mystic, frank, docp.
    I test to write and the machine operation with #1000 on A table. I dont know which number for B table.
    #1100=1;
    N1 IF[#1000 EQ 1] GOTO99;
    GOTO1;
    N99 M99;
    now i am working with M98 and M00 on the first line of program.
    My machine number: FAANCPT92077
    Fanuc 18-M (Anderson router)
    The machine have two spindle, and one saw.
    anyone have idea please post here, i dont want to call service... hihihi
    When finished this problem, i will post full O9001
    Thank you everyone,
    Regard
    Nguyen
  4. #24
    Apr 2010
    89
    My apologies for the confusion, Nguyen stated in an earlier post that his tool changer works OK so the problem must be elsewhere, from another post Nguyen stated
    'M100 and M101 use to call subprogram. That code on the top of program. When use it, it wait we push OK button on the table then machine will run.'
    From this I thought M100 might call a subprogram that checks which table is setup and ready to machine on his Anderson when he pushes the OK BUTTON ON THE TABLE.
    I was just giving an example of how the ACE-H100 knows when the next pallet is ready to be machined that might give Nguyen an idea on the subprogram that MIGHT need to be written using user inputs to check when a button is active for the M100 call.
  5. #25
    Quote Originally Posted by dcoupar View Post
    Mystic,
    Dave
    Sorry, I skim read the beginning of the post. My Bad
  6. #26
    Jul 2010
    I wrote macro program
    O9001 (Macro for change pallet);
    G91 G28 Z0;
    G90 G49 H0;
    G81 G0 X#502;
    #1100 =1;
    IF[#1001 EQ 1] GOTO100;
    GOTO1
    N99 M99;
    N100 M99;
    It operation very well for two tables, #1000 for Y table and #1001 for V table
    Parameter 6071 i write 100,
    Main program follow:
    O8000 (MAIN PROGRAM);
    M100;
    IF[#1101 EQ 1] GOTO1000;
    M98 P0456;
    M99;
    N1000;
    M98 P0457;
    M99;
    O0456 (SUB PROGRAM FOR Y TABLE)
    O0457 (SUB PROGRAM FOR V TABLE)
    That for Fanuc 18M
    Thank you for your help.
    Regard,
  7. #27
    Jul 2010
    Successfull!!!
    Hi FrankCNC,
    Thank you for your help,
    I wrote program from your information, i post here
    That is Macro to change table for Fanuc 18M
    O9001
    IF[#1003 NE 1] GOTO100
    N5 IF[#1000 EQ 1]GOTO10
    IF[#1101 EQ 0] GOTO5
    G91 G09 G00 Z[0-#5023]
    G91 G09 G00 X[#501-#5021]
    G04 P300
    GOTO5
    N10 G91 G17 X0 Y0
    M50
    #1101=1
    #1102=0
    M60
    M99
    N100 IF[#1000 EQ 1] GOTO120
    IF[#1001 EQ 1] GOTO130
    IF[#1101 EQ 0] GOTO100
    IF[#1102 EQ 1] GOTO110
    G04 P300
    GOTO100
    N110 G91 G09 G00 Z[0-#5023]
    G91 G09 G00 X[#502-#5021]
    G04 P300
    GOTO100
    N120 G91 G17 X0 Y0
    M50
    #1101=1
    #1102=0
    M99
    N130 G91 G17 X0 V0
    M60
    #1101=1
    #1102=1
    M99
  8. #28
    Apr 2010
    89
    Hi Nguyen,
    Good to hear you've been successful, I'm surprised that the User Inputs for the Daewoo are the same as the Anderson, I would have thought they would have been machine specific. I only listed them as a guide to show what to look for in you Anderson literature and machine.
    I worked out the Pallet User Inputs for our machine by going into CNC/PMC then PCDGN then searching for UI31.G to bring up the User Input screen then seeing which User Inputs changed from 0 to 1 or 1 to 0 when I changed the pallets on the machine.
    Regards,
    Frank.
Page 2 of 2 12
  1. Fanuc 0M number and dripfeed?
    By jeppes in forum Fanuc
    Last Post: 07-12-2023, 05:15 AM
  2. Fanuc Part Number/Revisions
    By botts_ in forum Fanuc
    Last Post: 07-27-2009, 05:10 PM
  3. 078 alarm (number not found)
    By jorgehrr in forum Parametric Programing
    Last Post: 06-23-2008, 07:57 PM
  4. 078 alarm (number not found)
    Last Post: 06-12-2008, 08:12 PM
  5. Replies: 1
    Last Post: 08-22-2007, 06:39 PM
