587,418 active members*
3,781 visitors online*
Results 1 to 10 of 10
    Jul 2008
    267
    Double sided carpet tape
    I have been using 3M double sided tape for parts holdown - especially aluminum sheet or fiberglass sheet. Since all my work is cut through I really haven't been able to use vacuum effectively.
    Anyways the 3M tape is expensive, so I decided to try carpet tape. I went to the local hardware store and bought a couple of different brands. Both worked just fine. However, when it came time to pull off the tape - it turned out one brand was a nightmare. Its adhesive was very sticky. It took a long time to clean up my parts, trying everything from lacquer thinner, acetone, xylene and methyl hydrate. Took a lot of elbow grease.
    Sorry to say the brand name was not printed on the inside of the roll. So make sure you experiment first before committing to using any particular tape.
    Apr 2005
    88
    Alternatives...
    Just thought I would let you know the brands that I have used in the past. Permacel is AWESOME. It sticks great and comes off with Isopropyl Alcohol. It is pricey, but it holds great. There is also a brand that is a little cheaper called Reel. I couldn't seem to find them online. Happy hunting.
    Jul 2008
    267
    Good to know some names. The 3M and the other brand of tape I used did not require any chemicals to remove.
    35538
    I use golf club grip tape from Golfsmith. It's similar to tan colored masking tape, but stronger and stickier (and double sided). As long as you don't leave it on for a few days, it comes off easily.
    Feb 2009
    2143
    Did you try Goo Gone on the "stubborn" one? That stuff works wonders...
    Mar 2010
    162
    Quote Originally Posted by analogman View Post
    I've been using an Ace Hardware brand that is similarly sticky. Naphtha wipes it right off. I swear that stuff's the original Goo Gone.
    Aug 2008
    409
    I sometimes use the double sided tape that comes with the Window Insulation Film, the clear plastic sheet you use in the winter to cover your windows.
    The tape that comes with is is sold separatly and is very sticky, double sided, cheap, and best of all, comes off cleanly.
    Nov 2008
    643
    If your looking for an alternate to tape try a pin nailer. I pen the pattern first just to make sure I don't run into a pin then fire a few pins in various locations, including any internal shapes that are fully cut through. The pins are very secure but leave a very small hole in the work. pry the work off and either pull the pins out of the spoil board or dremel them down below the surface. I'm using pins on 3/32 to 3/8 burch ply. btw my cad/cam doesn't easily add tabs to the shape which might prevent the need to pin internal to the cut shape.
    Oct 2006
    735
    I've used a double sided tape from the TapeIT brand. Felt like a double sided vynal tape like if you would have taken black electrical tape and double sided it. Maybe was a little thinner then that would have been.
    Course the tape roll came with some other stuff I got so not sure the exact type seeing it dind't have a part number printed on the roll. Some day I'll try to contact TapeIt to try to get some more.
    b./
    May 2003
    162
    Woodcraft has a tape they use for wood turning on lathe.
    It's called MillSpec. I use it for holding down aluminum.
    No movement, or residue, holds big time.
    Wipe both surfaces with alcohol first.
  1. double sided hold down
    By ronateah in forum WoodWorking Topics
    Last Post: 11-07-2007, 01:30 AM
  2. Double sided tape
    By Greolt in forum CNC Tooling
    Last Post: 09-17-2007, 10:11 PM
  3. Double Sided Tape? Really?
    By kentavv in forum MetalWork Discussion
    Last Post: 12-03-2006, 05:47 PM
  4. How to get that darned sticky double sided tape off a milled pcb ?
    By bobJandal in forum CNC Machine Related Electronics
    Last Post: 10-06-2006, 01:53 AM
  5. double sided job setups
    By july_favre in forum Uncategorised MetalWorking Machines
    Last Post: 06-14-2004, 04:27 PM
