So I am a bit of a noob, but I am learning.... I have gotten the setup, fixture offsets, tool offsets, etc all under control...
So, that said, today I was running some 16" x 22" long x 3/4" 6061-T6 plates - just milling some pockets, slots, and drilling some holes... The post was about 29000 lines, in increments of 100....
At around line 27100 - which were just coordinates for the final slot I was milling, the spindle shut off, and all motion stopped....command line was up as if the program had ended....however no command was given to end the program... Has anyone seen this before?
I was drip feeding the data using Predator.
I was using carbide end mills, and some SGS S-carb end mills so my feed speeds were pretty quick, and my spindle speed was maxed at 10k...
Note when it stopped there were no error messages - it was just at the command line.
Thanks in advance!
