588,510 active members*
4,911 visitors online*
Page 6 of 7 4567
Results 101 to 120 of 126
  1. #101
    Jan 2008
    8
    Lead Screw Question
    Blades,
    Nice job on the lathe. I'm really interested in converting mine in a similar way.
    One question! Did you use the Delrin nut and the lead screw instead of a ball screw because of cost? Also, have there been any problems with using it so far?
    Thanks a lot.
    Bob Keyes
    Bob Keyes
  2. #102
    Nov 2007
    616
    Thank you Bob!
    I opted for the delrin nut & ACME leadscrew for both cost and simplicity. Although running has only been limited to jogging and bench-testing, I really don't forsee any issues to arise from it. I also picked up a couple extra delrin nuts in case wear becomes an issue, but delrin is tough as nails and generally wears great.
    The cost of small ballscrews was more than I cared to spend, although it wouldn't be out of the question to upgrade to them at some future point, I really don't forsee the need. There is extremely little backlash in this setup, and is capable of taking a much higher load than you would typically see on this size machine.
    <a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
    <a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
    <a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
  3. #103
    Mar 2005
    140
    Amazing conversion, one of the best I have seen.
    If it was mentioned I'm sorry, but what did you do for spindle control?
  4. #104
    Nov 2007
    616
    Quote Originally Posted by levelzero View Post
    Thank you very much levelzero, I appreciate your appreciation! :rainfro:
    No, spindle control has not been addressed too much, but it is still high on my hit-list of things to complete. Main issue is, I am utterly clueless as to how to integrate spindle control.
    I am utilizing the C3 index pulse card and optical gate shown here:
    http://www.cnc4pc.com/Store/osc/prod...roducts_id=129 and a slotted disc. I verified operation of it, but the output wire is just an orphan at the moment. I am using a G540 for control, but have no clue as to what else I'm lacking (other than smarts) to fully integrate the spindle control. I've only got the OEM speed control, so obviously I have to interface with that somehow.
    Any input would be greatly appreciated, as I'm currently at a brick wall. With other stuff going on, this project has been neglected for awhile.
  5. #105
    Apr 2009
    144
    I've been following your build as I have the same lathe. Have you made anything with it yet?
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
  6. #106
    Nov 2007
    616
    Not yet Dustin, just playing with Mach and trying to figure out the spindle control.
  7. #107
    May 2003
    233
    i would like to say one thing about mach3 turn spindle speed control if you
    want good threads i found manual pot control gives you better rpm control
    when threading 1 to 2 rpms var i have been using the software on mills and
    lathes for years and i would like to ask is + - .003 good enough for these
    machines we BUILD?
  8. #108
    Nov 2007
    616
    Good info on the software vs. manual pot control. I'm surprised to hear that, actually.
    With regards to +/- .003, I guess it really depends on what you're doing with it and what the tolerance applies to. When getting down to the nitty-gritty tight tolerance stuff, it has as much or more to do with the machinist as it does the machine. A highly experienced machinist knows how to deal with machine play.
  9. #109
    May 2003
    233
    by the way i have been machinist for 28 years and yes on manual lathe i can
    hold better than +- .003 i was talking about many parts over 2" long steel
    off my 7x12 cnc lathe yours? most of the time they come +-.001 just takes
    constant upkeep
  10. #110
    Nov 2007
    616
    I was a machinist (mostly Bridgeport) for almost 20 years, then tool design for the next 10 years, but machining whenever I could get my hands on one
    I haven't really machined anything since doing the CNC conversion, but I would expect decent results from it.
  11. #111
    Nov 2007
    616
    Wow, time to shake the dust off this thread and update!
    After lots of thinking, looking, and playing around regarding a control box to house the G540, power supply, and other misc. wiring I decided to do something different (those who know me know that I'm all about doing something different ) I decided to make the lathe self-contained (with the exception of the computer, of course) and built everything into the lathe. I was on a roll yesterday, and it just started going together. It's not completely done, but maybe 90%. I still have to wire the cooling fan and the spindle encoder. If for some reason this turns out to be a stupid idea, or I change my mind, I'm only out a $15 change-gear cover after hacking mine up.
    Here's some pics. The bottom pic what it looks like from the inside. There will be only 2 cables coming from the lathe: the power cord and the printer port cable.
  12. #112
    Mar 2004
    1306
    Nice!!!
    I have my drivers in a separate 19 rack cabinet, and have about six cables between the lathe, the vfd, the power board and the rack. Your set up is much better.
    Regards,
    Mark
  13. #113
    Mar 2006
    19
    SLICK!
    That's a really nice idee for the controller!
    Cheers!
  14. #114
    Oct 2006
    59
    Blades, SLICK! I can't wait for you to get your spindle encoder/control sorted so I can "steal" your design!
  15. #115
    Nov 2007
    616
    Thanks guys, glad you like it!
    Mark, I sure don't know about it being "better" than your setup, as it's pitfalls are yet to be discovered. But it is different. I was looking at it last week, trying to decide what to do and where to mount the controller. At first I was looking at a way to mount it below the power supply on the back, but then discovered it would fit nicely in the change gear cover. Soon after I was hacking away
    Justin, steal it at your own risk, as its unproven
    I need to install a switch so I can switch between manual spindle control or programmed spindle control. I found a thread on here that details how to do it.
  16. #116
    Feb 2010
    Slick! Now you need a cover for it
    Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
  17. #117
    Nov 2007
    616
    Jon, long time! Yeah, I look at the cover idea fairly regularly, but the design just hasn't clicked yet.
    I've been on vacation for the last 12 days, but back to work tomorrow. Would have got more done on the lathe but was distracted by a couple new toys (new Tacoma and new Ruger MK III)
    BTW, I was in WL this past weekend for a few hours, had to bring Nick home so he could go to a wedding in Louisville. Was extremely glad to find Dog-n-Suds opened again.
  18. #118
    Nov 2007
    616
    Got a bit more done the past couple of days. Everything is wired up with the exception of the output signal wire to the G540. Still trying to get an answer on how the CNC4PC Pulse Index Board is supposed to tie into the G540. Anyway, I've got a toggle switch wired in to switch between manual speed control or G540 spindle control. You can see the switch on the side of the control box on the front of the lathe.
    In all honesty, I'm not so sure I really like this setup as compared to a single, dedicated enclosure for the power supply & G540. Yeah, it's different, but it it really better?? I'm not entirely sold on it. The thought originally was to keep things neat, with only a power cable and parallel cable being the only external connections to the lathe. But I've still got cables exposed from the side & back of the lathe, so it's not as neat as I originally thought. I dunno... as I said before, I'm really only out a $15 change-gear cover if I decide to do something different.
  19. #119
    Mar 2004
    1306
    Hi Blades. I see what you mean. But I have six cables out of my lathe (X motor, Z Motor, VFD Control, VFD to motor, mains power, indexer (which should also have the home switches, but I didn't bother reinstalling them after the last maintenance - This cable needs to be redone properly). I still think your set up is much cleaner.
    Regards,
    Mark
  20. #120
    Jun 2004
    6618
    Looks great.
    Now you can remove that HF label and design your own to put in it's place.
    Lee
Page 6 of 7 4567
  1. CNC Project Started
    By NotSqueaky in forum CNC Wood Router Project Log
    Last Post: 09-10-2014, 12:41 AM
  2. New Project Started
    By Rumblebelly5 in forum Joes CNC Model 2006
    Last Post: 09-15-2012, 10:50 PM
  3. Need some help getting started on a CNC project
    By thompson4433 in forum MetalWork Discussion
    Last Post: 06-05-2012, 11:47 PM
  4. My 4x8 project has started
    By MetalHead6263 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-31-2012, 07:30 AM
  5. Started new project
    By rustamd in forum DIY CNC Router Table Machines
    Last Post: 05-31-2009, 04:12 AM
