587,231 active members*
4,801 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > One shot oiler question
Results 1 to 6 of 6
    Mar 2008
    331
    How many "shots" do you pull when oiling your machine ?
    Right now I do 10-12 pulls to make sure that the machine has oil in all areas. Because less then that and I don't see oil spilling out of the ways on the back.
    Mar 2009
    163
    Maybe 6 pulls to start, and a pull or two every once and a while.
    10-12 must take a fair bit of time.
    I notice that some ways start spilling before others.
    Mar 2008
    331
    I notice too that the some spill before others. The last one to show oil is the top of my z linear. The bottom one is almost instantly , the top the the very last thing I notice.
    Yeah it does take more time to oil then I like....
    Jan 2007
    99
    The oil gets dispersed differently for each axis, x and y seem to be about the same with mine. Rather than waste oil trying to get it to the z axis ways, I just manually oil them.
    -Greg
    "If Necessity is the Mother of Invention, then Who's the Father?"
    Mar 2008
    331
    I did 8 pulls last night and waited, it slowly came out of the top z bearing. So I ll do 8 pulls and then maybe one later in the day as well.
    I manually oil my other mills, so while it wouldn't be much to do it with this one as well, I can't get to all the ways underneath good enough, so I would rather waste a little oil in hopes that I am really getting oil to them also.
    Todd
    Jun 2007
    3891
    1 pull gets oil ooozing out the x ball screw on my nm200, but i think mines got a different oiler than the new ones. its got a force feed lever. 8 pulls seems extreme.
    then nm145 has a slow action pull handle, and it seems to be fine with 1 pull getting all around.
    in my experience, you dont want lots of oil, you want a nice thin film of clean oil. if you overtravel the 200 on the saddle you can see easily if its dry or filthy. 1 pull every 3-4 hours running does the 200 well.
  1. One-shot Oiler Question
    By rowbare in forum Tormach Personal CNC Mill
    Last Post: 09-07-2010, 04:12 PM
  2. Automatic oiler question
    By TarHeelTom in forum Bridgeport / Romi Lathes
    Last Post: 06-16-2010, 02:55 PM
  3. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
  4. One shot oiler
    By Bubba in forum Uncategorised MetalWorking Machines
    Last Post: 12-01-2009, 03:39 AM
  5. Timer / oiler question
    By chrispy in forum Mach Software (ArtSoft software)
    Last Post: 08-21-2005, 03:36 PM
