Most likely the CRT emission has gone way down, if you are really lucky you may find some old B&W monitors if the screen is monochrome, basically I have mixed and matched crt's off old monitors.
The critical areas are neck dia., filament voltage (usually 12v), and deflection angle of the rear glass, front mounting is not that critical if the size is the same.
Usually there are adjustments but some are in some obscure places sometimes.
OK, if it is LCD forget the foregoing.
Al.
Albert E.
