587,786 active members*
4,859 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Tool Change Fault - VMC15 1995
Results 1 to 3 of 3
    Sep 2010
    Hello,
    I have a Fadal VMC 15 RT Model 914 from 1995, a vertical cnc.
    When the tool change occurs, and when the spindle it moving down to pick up a tool machine faults out and give me an error: emergency stop - take appropriate action. However the machine did not hit anything.
    It happens in manual (tc,1) or auto mode. It first happened occasionally, and its now all the time. There is no collision with anything. The location seems correct. I have tried changing the Z home location up and down using the command (setz) and that did not help.
    Thanks in advance for your help.
    Mar 2010
    atc
    go to enter next command type DI,enter,DS,enter this will bring up the sensor screen go thru the atc sensors.when you are done you will need to type X,enter to get rid of the screen.
    Feb 2008
    547
    Smile Here is ...
    ...a link about the same (nearly) problem alex helped me with.:idea: See if that helps also.
    http://www.cnczone.com/forums/showthread.php?t=111378
    Steve
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. Replies: 0
    Last Post: 02-14-2010, 07:26 PM
  3. bridgeport tool change arm break off fault
    By peter doyle in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2007, 09:54 AM
  4. kuraki kbt-11wdx tool change fault
    By MAINTAINERS in forum Fanuc
    Last Post: 04-19-2007, 04:11 AM
  5. 1995 VMC15 Error#3 Motor overload
    By Billet Sean in forum Fadal
    Last Post: 03-07-2007, 09:39 PM
