588,053 active members*
4,153 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Mar 2008
    56
    VSDE and Fanuc motors.
    DO you know which Fanuc AC motors can run with the VSDE.
    I tried some Control Techniques which did not work even after I replaced the encoders.
    Im running some 750W DC servo motors right now but they arnt very gutsy at 2Nm.
    So I was hoping to goto the following as I have 2 available locally at a good price.
    FANUC A06B-0522-B351 AC SERVO MOTOR +
    3 PHASE
    8 POLES
    STALL TORQUE 22 Nm
    STALL AMP 2.9 AMP
    90 V
    AMB TEMP 40 DEG C
    EXCIT PERM MAG
    INSULATION CLASS F
    APPROX SHAFT DIA 1/2"
    PULSE CODER :
    A290-0521-V581 PULSE CODER ABS2000P
    Mar 2008
    56
    These are the other two motor options....
    FANUC A06B-0315-B08-7008 AC SERVO MOTOR
    TORQUE (STALL) 12NM
    AMP (STALL) 7.6 A
    RPM 3000
    PHASE 3
    150 VOLTS
    OR
    FANUC A06B-0128-B675#7008 AC SERVO MOTOR, USED
    OUTPUT 1.4 kW
    114 V
    7.5 AMP
    200 HZ
    3000 RPM
    3 PHASE
    200 V INVERTER
    STALL TORQUE 6 Nm
    STALL AMP 10
    Dec 2003
    24220
    Quote Originally Posted by evo4wrx View Post
    Looks like you have the absolute encoder there, most likely off of a robot.
    Does the Granite use the encoder for commutation? As the Fanuc AC servo's use a proprietary 4 bit code for commutation.
    Al.
    Albert E.
    May 2009
    281
    If you can get the encoder pulses off the encoder the granite devices will run it I have one that had an absolute encoder an absolute encoder but I was not able to get the encoder wired so it would work. the vsde's sense the commutation requirements and will then run from the encoder count, I just replaced the encoder with a differential encoder, I made an adapter plate to fit the motor and a nylon adapter to fit the coupling on the motor. it seems to work just fine now.
    Mar 2008
    56
    I had 2 control techniques that were resolver AC motors that I replaced with Renco encoders but the things just wouldnt run. So im a little gun shy now leaving the world of DC. The other option is i go to Faunc 10M yellow caps but all the motors around are just so old.
    Mar 2008
    56
    Can anyone confirm if this motor will work?
    Fanuc Model 10S
    Type A06B-0315-B032
    12 NM
    3 Phase
    7.6AMP
    Excit Perm Mag
    2000 RPM
    150V
    8 Poles
    Pulse coder
    Not so fussed about the encoder I can pull them off and replace them with my Renco encoders I have a heap spare.
    May 2009
    281
    I am running model 5s with some with pulse coder some with trd shaft encoders coupled to the back of a cap screw in the end of the tapered shaft that the pulse coder was bolted to. I milled a stand off that use the original mounting screws.
    the specs on the model5's are 110v and 6.8 amp 5.9nm. essentially
    the same motor except voltage and power so it should run the model you cited
    the alpha series will work fine to but I had to change the encoder. it has a different mount system than the pulsecoders, ti has a single slot swash plate on the back of the motor . I just made a nylon part that mated with it and was able to use more of the original mounting hardware to set it up.
    Dec 2003
    24220
    The B032 shows up as a 2500p Absolute encoder.
    I have used a shoulder bolt with 5mm(?) thread and shoulder to suit the Renco encoder.
    Al.
    Albert E.
    Mar 2008
    56
    Thanks 10 S it is then.....that will bring the lathe upto some decent speeds and get rid of the gears finally.
    Dec 2003
    24220
    They make nice spindle motors also.
    Al.
    Albert E.
    Mar 2008
    56
    I think I overlooked one slight issue.
    Whats the dimensions of the motor 5s and the 10 s...could anyone help me or point me int he direction for that one. Ive googled about every combination of words that might relate to it but it comes up with nadda.
    L /w /H
    thanks.
    Dec 2003
    24220
    5S motor and flange 5" sq, length 12" (w/o brake) flange to encoder end.
    Straight Shaft - 2".
    Motor 14" OA.
    Al.
    Albert E.
    Sep 2004
    1207
    The motor part will always work with VSD-E as long as it's permanent magnet motor (DC/BLDC or AC). All servo motors that I have came across have been permanent magnet type. Only totally incompatible type is induction motors (typically not used as servo due to poor dynamic performance).
    So pay attention to encoder. It must output incremental quadrature encoder signals to work with VSD-E.
    All Fanuc (any any other brand, too) servos will work with VSD drives if they have compatible encoder attached. Commutation tracks are not needed as VSD-E can commutate based on encoder only.
    Dec 2003
    24220
    Quote Originally Posted by Xerxes View Post
    The majority of Fanuc red cap AC motors are 8 pole P.M. motors, the 6 pole P.M. appear to be fitted to Fanuc Robots for some reason and all robot motors are fitted with absolute enc. as a rule.
    Al.
    Albert E.
    Mar 2008
    56
    I ended up with 4 x 5S 3000 RPM motors. Should do the trick...will get my lathe rapids upto about 25m / min which I will be standing in the car park to watch
    Will post some pictures tomorrow of the lathe build...its been a monstor effort and Ive been through 2 chasis builds to end up back on an old 2.5m engine lathe. Typical. Dont re-event the wheel. Fail.
    Aug 2008
    1166
    Might be too late to help, but from what I've seen generally the older Fanuc red cap series with part numbers A06B-0xxx-Bxxx series motors that end with 01,02,03,04,05,06,10 have incremental encoders. So for example, A06B-0315-B004 is a 10S motor with a 2000 pulse incremental encoder. I have some of these and have tested them with a scope and the output looks like an incremental encoder anyway. I eventually plan to use these with some VSD drives. The higher numbers are absolute or serial encoders.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Sep 2010
    Hi there Al
    We spoke some time back regarding our large 5 Axis mill still having issues with the Granite devices Drives .Seems to take for ever to get granite devices to respond to issues
    Are you avalible to help us with the last lot of Questions
    We are almost at a point were we are going to throw out the Granite stuff and deal with more reputable companies
    Dec 2003
    24220
    Quote Originally Posted by NZCNC View Post
    If I can, I will.
    You can either post here, PM me, or email direct.
    Al.
    Albert E.
    Sep 2010
    Thanks Al
    These are the issues as follows,
    We still cant get the drive to enable correctly from the VSDEPI interface (attached is a typical .DRC config file )
    Drive will not enable with this configuration ,Even though enable 1 is lit in Mach 3
    With 1 only cmd connector plugged into VSDEPI but not connected from VSDEX, I would expect to get voltage bettween pins 13 and 16 (analog in 2).However there is no voltage present when enabled or disbled
    No # 2 Home limits signals do not work with cmd plug connected at VSDEX but unplugged from VSDEPI pins 2,7 = 5 VDC
    pins 7,11=5 VDC when faulted OVDC when not faulted
    pins 7, 12 = OVDC when home switch ( encoder pins 4 &8 bridged )configuration to opto 1 =home limit " Then i red change of state on pins 7 ,11
    So opto 1 works fine and opto 2 does not work on at least 3 drives I tried
    On a positive not we have step and direction working from Mach 3 and GDtool
    Hope this makes sence to you
    Regards
    Tim P.S cant see where you attach files on this !!!!!!!!!!
    Dec 2003
    24220
    I will look it over and see if I see anything.
    If you Go Advanced when you post, you can make attachments.
    Al.
    Albert E.
Page 1 of 2 12
  1. VSDE 160 BLDC problem
    By evo4wrx in forum CNC Machine Related Electronics
    Last Post: 02-03-2015, 03:04 AM
  2. fanuc 'red cap' motors
    By mmjpotter in forum Servo Motors / Drives
    Last Post: 11-10-2009, 10:00 PM
  3. FANUC 0M-C servo Motors & amplifiers
    By gbowne1 in forum Fanuc
    Last Post: 07-03-2009, 06:08 AM
  4. Fanuc 5M motors
    By oskars in forum Fanuc
    Last Post: 03-05-2007, 08:37 PM
  5. Gettys FANUC Motors
    By spottiepop in forum Fanuc
    Last Post: 07-09-2006, 02:49 PM
