You are right it does hit the base. I will have to mill a step in the front of the nut so the majority of it will pass under the base.
Couldn't you just make it a lot shorter? I know the ball nuts I planned on using only had 1/2" of threading so I don't see why it needs to be any thicker than that.
The nuts fit into the block and the flange will be bolted to the outer of the block. there are no threads on the nut to remove the flange and screw the nut directly into the block.
I have a way I might to it different that will give me another 1/2" of travel but we will see.
So shouldn't it just need to be as thick the number of threads desired? Why do the ball nuts needed to be surrounded by the block I guess? Comparing this to Bob Warfield's Y-mount this seems excessively large.
That picture makes it clearer and it looks like it might clear the top of the base without having to cut out a big chunk.
Well I got both of the X/Y ballnut holders finished and on the machine. I need to order my timing pulleys so I can finish up the machining of the ball screws. I received the 1-shot oil pump today after waiting 3 weeks for it to arrive from the UK. I am going to start cutting the oil grooves into the saddle and work on the 1 shot oil system for now.
Waiting on my timing pulleys to arrive and working on the 1 shot oil system. Here is the manifold I have made to distribute the oil to all of the ballnuts and ways.
Looks good .. where will it get mounted?
I've thought about mounting a manifold on the back of the column, but still not sure if that will work for me or not.
Also what kind of tubing do you plan to use? I want something that will be strong but flexible. I've been thinking about the white plastic stuff that can be bought at any hardware store. Just not sure it will hold up to repeated motion.
gd.marsh
I was also planning on the back of the column close to the base.
As for tubing I thought about the hard plastic tubing but decided to just use some simple 1/4"OD clear plastic tubing that I got from lowes. You can find it in the same place as the hard plastic stuff but more flexible and the pressure from the 1 shot oil pump will never blow out the line so now worries there.
Flenser, does this look familure?
Got the ballnuts back on the screw and the y-axis nut mount between them.
One question- when I put the 2 nuts on there and if I screw the outer nut all the way down the holes do not line up. this leaves a small gap and lets me put a load between the 2 nuts so there is 0 backlash. So how should I take up the gap that isn't needed to load the nuts?
Hey, that does look familiar, and you don't need to paint it green to keep it from rusting : )
The width of the block added to the thickness of the flange has to be a multiple of 5mm. You can also trim one end to get it correct. Determine how far you need to turn the nut in degrees to line the bolts up, and multiply by 5mm/360 deg. Trim that off the end, and the nuts should clamp the block tightly at the point the bolt holes line up.
Thanks, I need to turn it around 90deg to get them to line up. so looks like I will be taking off around 1.25mm. So small I might just do it on the base sander.
Yeah I went with 7075-T651 aluminum(I have 3, 2.5"X3"X10' bars of it). we will see how it stands up.
Got the oil manifold mounted.
I found if the mounting surfaces of the ballnuts were even a little out of parallel, they would bind when I tightened the bolts. I don't have any experience with base sanders, but I thought I would mention that, in case it's not all that accurate.
7075 is probably stronger than the 1018 I used...
Wow wouldn't have expected that, according to onlinemetals.com 7075 aluminum is stronger than 1018 steel.
1018 Mild (low-carbon) steel = Ultimate Tensile Strength, psi - 63,800
and
7075-T6 Aluminum = Ultimate Tensile Strength, psi - 83,800
Yea, I wish I knew a quick way to recognize 7075 in the scrap yard. They charge for AL by weight, regardless of grade. By the time the stuff turns gray and is recognizable, it's mostly been picked over.
I wish I had a scrap yard to goto lol, I was lycky on the 7075. I got it all for free from some welders at work. It had been sitting around in a container for a few years and they said they were never going to use it. I got 3 bars at 2.5"X3"X120" and a sheet of 1/8"X48"X120". I looked it up and from onlinemetals.com the bars would be $650 per and the sheet would be around $925 :-)
Got the pneumatic cylinder done for the quick change tooling. I now have to work on mounting it.
In regards to the one shot oiler setup, what will you be using to distribute the oil evenly so that it doesn't all get applied to the nearest "exit"?
Dave
Dave->..
