587,485 active members*
3,239 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 16-TB Tool Geom / Wear not Updating
Page 1 of 2 12
Results 1 to 20 of 33
    Jan 2010
    33
    Exclamation FANUC 16-TB Tool Geom / Wear not Updating
    Dear colleagues,
    We have one machine here that was conventional and now we put one old (very old) FANUC 16-TB on that.
    The machine is fully parametrizated as well as drives and control itself, tool changes, the machine works fine, back lash and lead screw table are setted and everything is fine. BUT
    The values on Geometry and in the Wear aren't updating the absolute coordinate system. To be able to evaluate the machine geometry and make some machining tests I had to insert the Tool Geometry Values on Work Offset, and then work with just one tool.
    Even the Wear isn't working. The screen is there, the measure - insert c - insert + and input are avaliable, the values are inserted correctly using the insert c, but when I program T0202 the change occurs but the values of absolute isn't working.
    Need help because I think that this function is on basic software package.
    If you can help me again I'll be glad.
    Jun 2008
    1511
    Take a look at the attached PDF parameter 3104 settings it shows the parameter setting for the display to use or not use the tool offset. This is probably your problem.
    Stevo
    Attached Files Attached Files
    Jan 2010
    33
    Hi Stevo,
    I'll try this parameter right now! I saw that this parameter is related with par 5002 so I'll check the both.
    Thank you by the advance.
    Jun 2008
    1511
    Your welcome.
    Stevo
    Jan 2010
    33
    I'd tried the parameter and nothing changes. Still not updating Abs values when T0202 or any other tool is called.
    Can the tool change routine O9000 making something wrong? I mean, there is no more parameters to control Wear / Geom behavior.
    A friend that was FANUC employee (the guy that wrote the ladder for this machine) told me some days ago that it can be a FANUC basic software issue that can be solved only changed the CNC EPROM where it's recorded.
    I have doubts about that, because it's soo simplest, It's just about program the T code and the values must be updated. I've never saw one CNC with this behavior before. My guess is that the tool change routine is making some mistake and not leaving the control to update the values.
    Jun 2008
    1511
    Can you post the 9000 tool change macro?
    You have the parameters set to use the last 2 digits as the offset value correct?
    Is the machine actually instating the tool offset and just not showing it on the program check screen?
    Stevo
    Feb 2006
    1792
    Quote Originally Posted by ecapatto View Post
    Dear colleagues,
    Not very clear what you are doing.
    If you are setting G54 work offset with one tool by touching off and measuring, you do not need any geometry offset for this tool. Can call this tool just by T0200 or T200 (assuming it is tool number 2).
    If you want to use T0202, the corresponding geometry offset (in row number 2) should be zero.
    Jan 2010
    33
    Stevo:
    - I'll try to post the tool change macro
    - The parameters set the Offset correctly, to use last two digits
    - No, the machine isn't updating the values, I have one test NC program to evaluate this situation.
    The T0202 appears on lower right corner in the screen, like it's active, but it isn't.
    Sinha_nsit:
    - I did changes on work zero (G54) to evaluate the machine geometry, because it was refoubished. But in the normal operation the operator needs to insert the correspondent data for each tool in each Geometry screem row.
    - Working like I did just allow operator to use G54 for tool 1, G55 for tool 2 .... It isn't the correct way. The correct way is to have G54 set up to workpiece end face, or chuck face or wherever they want and the tool geometry relative to that position. But FANUC isn't taking into account the value on that screem [WEAR/GEOM], I dont't know why.
    Even the Wear aren't working, as I told, I never saw one FANUC controller acting like this one.
    Jan 2010
    33
    Follow the Macro fot Tool Change: PLEASE HELP-ME
    FYI, the machine FANUC control have two channels, the second isn't in use.
    O9000(TOOL CHANGE)
    N10#110=#4001
    N20#111=#4002
    N30#112=#4003
    N40#500=FIX[#149/100.0]
    N50IF[#500GT8.0]GOTO1230
    N60IF[#500EQ#501]GOTO1300
    N70IF[#501EQ0]GOTO500
    N80G91G0G28Z0
    N81G90G0B[#501*45.0]
    N85G4P400
    N90IF[#1000EQ1]GOTO1240
    N100G91G30X0
    N110M50M53M54
    N120G4P500
    N130M52
    N140G4P500
    N150M55
    N160#501=0.0
    N170G90
    N180IF[#1000EQ0]GOTO1260
    N500IF[#500EQ0]GOTO1110
    N510G91G28Z0
    N515G90G0B[#500*45.0]
    N520G91G30X0
    N530G4P500
    N540IF[#1000EQ0]GOTO1250
    N550M50
    N560M54
    N570G4P500
    M580M51M53
    N590#501=#500
    N600G4P500
    N610M55
    N1100G#110G#111G#112
    N1110M51
    N1120M99
    N1230#3000=1(WRONG T VALUE)
    N1240#3000=2(OCCUPED POSITION)
    N1250#3000=3(NO TOOL AN THIS POSITION)
    N1260#3000=4(TOOL NOT OUT)
    N1300M99
    Feb 2006
    1792
    Simple first:
    Call tool number 1 by
    G54;
    T100;
    Does it work correctly?
    If yes, make geometry and wear values in row number 1 equal to zero. (You would need to edit both geometry and wear screens one-by-one, which can be selected by softkeys).
    Now call tool 1 by
    G54;
    T101;
    Does it work correctly (should be exactly same as previous case)?
    Feb 2006
    1792
    Use of #149 indicates that you are calling a sub by a T-code. Such a T-code in the main program does not have tool-change function; it just calls a sub 9000 (no other sub can be called). So, you need to insert T#149 in the sub, wherever you want a tool change (say, after homing). The T-code in the sub behaves like the usual tool-change code. Your sub does not have T#149 anywhere.
    (If you command T101 in the main program, 101 automatically gets stored in #149 for use in sub)
    Ignore my previous post.
    Jun 2008
    1511
    Sinha....regardless of #149 when you program a T0101 offset 01 should be taken into account correct??
    I am a bit stumped on this one right now. Let me do some thinking on this one.
    Stevo
    2932
    Quote Originally Posted by sinha_nsit View Post
    I believe this is only true if parameter 6001 bit 5 is set to 1. If 6001.5=0, a T-code in the main program is just a T-code.
    Jan 2010
    33
    Arrow
    Dear colleagues,
    I'd changed the Tool Cnage Macro inserting the code T#149 before M99 and the machine just stop at that block, start still green and nothing happens.
    The actual related parameters are (in machine):
    #6001.0 = 0
    #6001.1 = 0
    #6001.2 = 0
    #6001.3 = 0
    #6001.4 = 0
    #6001.5 = 1
    #6001.6 = 1
    #6001.7 = 0
    #5002.0 = 1
    #5002.1 = 0
    #5002.2 = 0
    #5002.3 = 0
    #5002.4 = 0
    #5002.5 = 0
    #5002.6 = 0
    #5002.7 = 0
    #3104.0 = 1
    #3104.1 = 0
    #3104.2 = 0
    #3104.3 = 0
    #3104.4 = 1
    #3104.5 = 0
    #3104.6 = 1
    #3104.7 = 0
    I have a guess of what is going on. I want to unrrelate the Tool Cnage macro from T code and assign this to M6 code.
    Assign the O9000 to M6 is quite easy, but how can I separate the O9000 from T code?
    Or if one of you have a better idea, I'm listening.
    Regards,
    Feb 2006
    1792
    Right
    If 6001#5 is set to 1, the T-code loses its tool-change function in the main program. It just calls O9000. In O9000, it acquires tool-change function. The best thing would be to test it:
    Set 6001#5=1 (edited)
    Have only M99 in O9000
    Now command T0101 or T0202 or any other number you wish.
    Nothing would happen.
    This is described in quite detail on pp. 150-151 of my book on macro. I have attached these pages for those who do not have this book.
    Set 6001#5=0 and command T0101 (no M30) in MDI. Does it take effect?
    If yes, set 6001#5=1 and again execute T0101. Does it work?
    If not, post your main program as well as modified O9000.
    Set 6001#5=0
    Jun 2008
    1511
    Dave…yes with the 6001.5 set proper parameter set it will call a sub with a T() call and set #149 to the modal T(). My assumption would be that no matter what this parameter is set to it should not affect the instating of the tool offsets.
    I never use the T() subcall for tool change. I always use a custom M6 to do so.
    Ok so are you still having problems with your original question of the tool offsets not instating?? Calling a macro with T() or M6 is not going to change the fact that your offsets should instate no matter what.
    Stevo
    2932
    Quote Originally Posted by stevo1 View Post
    Stevo
    It's as sinha_nsit stated in an earlier post.
    T101 in the main stores 101 in #149 and calls O9000. It does NOT perform a toolchange or turret index, and does NOT activate any offsets.
    To activate the offsets, there has to be a T#149 in O9000 somewhere.
    Jan 2010
    33
    Wink
    We got some progress here.
    In both cases, using M6 to call the Tool Change sub (pars 6001.5=0 and #6071=6) or inserting the T#149 into O9000 the Absolute Value now is taking in account the Geometry and Wear values.
    The problem now is:
    When par 6001.5=0 then there is no association with T and O9000 in MDI mode the control update the absolute values (taking in account the Geom/Wear) and stops at this single block. The cycle start led still on, no alarm raises. The control just stops, but now at least we know that there isn't nothing wrong with the control, just with the guy behind him(nuts).
    Any suggestion why the control stops at T command? Even withoout connections with the Macro?
    Thanks by the advance,
    2932
    The problem now is:
    If you simply MDI T101 and cycle start that, does it pick up the offset? What kind of machine is this?
    Feb 2006
    1792
    If using M6, which would call O9001 (with your parameter setting) as a subprogram, you need to insert the complete T-code, such as T0101, in O9001. Not a good idea.
    Therefore, you need to use M6 for calling a macro where you would be able to pass data to the macro. For this,
    Reset 6071, and set 6080=6.Then M6 would call O9020 as a macro.
    In the main program, command M6 T0101 (not T0101 M6), and insert T#20 somewhere in O9020.
    For more information, read the attachment.
    Sinha
Page 1 of 2 12
  1. Tool Wear Adjustment
    By nfrees114 in forum Haas Mills
    Last Post: 08-08-2014, 01:04 AM
  2. Fanuc 0TC and Tool Wear Offsets
    By rrbmachining in forum Fanuc
    Last Post: 07-05-2010, 04:06 PM
  3. tool library not updating
    By R.DesJardin in forum SprutCAM
    Last Post: 11-10-2009, 06:42 PM
  4. tool wear indicater
    By Vern Smith in forum Haas Mills
    Last Post: 03-20-2007, 07:09 PM
  5. Fanuc code needs updating.
    By Roberts in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-22-2006, 02:45 AM
