I'll try this, but I have a question:
Without any macro attached to T code and without M6, T0101 should be able to update the Geom/Wear (already working) and then finish the command by jumping to the next block without do anything else, no macro, no PLC waiting. Just activate the Geometry and then finish the command.
The problem now is that T command (pure) isn't being executed at all, T update the values on ABS, but the command isn't able to finish itself.
Regards,
