603,818 active members*
4,580 visitors online*
Results 1 to 2 of 2
    HobbyCNC, Gecko together?
    I have a homemade CNC and it's running great with the HobbyCNC pro board driving the 3 stepper motors
    I have on the way a Gecko 320X and some servo motors to try and use it for a 4th axis that I've made
    I'm trying to figure out how I'm going to hook everything up - using Mach3
    any ideas?
    Thanks!
    Feb 2007
    4550
    Post
    GeeksGoneBad,
    The simplest solution would be to get a in line DB 25 breakout.
    Breakout pins 8 and 9 for the add on Gecko project.
    Pass the remaining pins on to the Hobby-CNC Board.
    https://dcc.ligo.org/cgi-bin/DocDB/S...ent?docid=4831
    JUMPER BOX DB25 MALE/DB25 FEMALE - AB972-R
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. Whats the best motors to use with Gecko or HobbyCNC?
    By The CNC Man in forum Stepper Motors / Drives
    Last Post: 07-31-2009, 03:19 AM
  2. Wiring 8 wire hobbycnc with Gecko-like drive
    By Guldberg in forum Stepper Motors / Drives
    Last Post: 07-21-2009, 02:52 AM
  3. HobbyCNC vs Gecko 540
    By LogansMind in forum DIY CNC Router Table Machines
    Last Post: 04-17-2009, 03:10 PM
  4. hobbycnc
    By Mr. midnight in forum DIY CNC Router Table Machines
    Last Post: 05-25-2007, 08:06 PM
  5. To Gecko, or not to Gecko...that is the question!
    By samualt in forum Gecko Drives
    Last Post: 09-23-2003, 02:42 AM
