588,611 active members*
7,588 visitors online*
Results 1 to 9 of 9
    Oct 2010
    FS10T Address Error_Bus Error
    I have Sliding Headstock lathe machine with Fanuc 10T controller.
    But frequently giving Following alarm-
    ADDRESS ERROR
    FFCDC9C
    FFC4E2
    FFC522
    and sometime,
    BUS ERROR
    FFD434
    FFC496
    FFC4D6
    When I do Reset gives following
    1 DUMP MEMORY
    2 -
    3 CLEAR FILE
    4 SETTING
    5 -
    6 END IPL
    plz help to start the machine , If any procedure.
    thanx in advance
    Jun 2008
    1511
    Here is the procedure for reloading all of your data. Your option parameters will have to be entered in hexadecimal format.
    To enter in option parameters
    1) Power up machine with "-" minus and "." decimal point depressed
    2) Key "99" and "Input"
    3) Key in "3" or whatever # axes in parameter 9000 @ "AXIS" prompt
    4) Step through options by number and key new Hexidecimal codes and "input"
    option 1=9100, option 2=9101 ect. Just push input if no change is required
    5) If "clear files" appears, hit "Y" - will erase programs etc.
    6) When 1st menu appears, key "6" and "enter"
    Once complete then enter in all of your PMC data. Timers, counters, keeprelays etc. Then setup your RS232 parameters and load the NC parameters along with programs and any offsets.
    Stevo
    **Edit** sorry forgot to mention that you may have to do a master clear the files before doing the above by holding down "7" and "9" at power up then press "99" and "input" when the IPL menu appears. It will ask to clear, press "Y".
    Oct 2010
    Thanks stevo,
    I'll do it and will let u kno.
    have a gud day.
    Jun 2008
    1511
    Your welcome. Let us know.
    Stevo
    Oct 2010
    Hi stevo,
    i have tried the procedure, cleared memory, reloaded all parameters but still these alarms comes intermittently.
    pls suggest
    Jun 2008
    1511
    Did you try the master clear with "7" and "9"?
    Stevo
    Oct 2010
    yes stevo...
    itried the same.
    Jun 2008
    1511
    Well then my guess then would be that it is a hardware issue on a board. I would not know where to tell you to begin. Maybe memoryman can jump in with some ideas of where to start looking.
    Stevo
    Sep 2010
    125
    can you tell me if your mother board is an analog (040 or 041) or a digital one (0320 or 0190) and did you have an add memory pcb ?
  1. X & Y address
    By Ashish B in forum CNC Machining Centers
    Last Post: 03-24-2010, 04:25 AM
  2. HELP! G100 IP address
    By noyloj in forum G-REX
    Last Post: 12-13-2009, 10:54 PM
  3. address code error!
    By sridhartsr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2009, 06:27 PM
  4. Tape Drip feed on Meldas50 - P32 Address Error
    By firechcken in forum DNC Problems and Solutions
    Last Post: 05-26-2008, 03:16 PM
