588,385 active members*
5,258 visitors online*
Results 1 to 5 of 5
    Oct 2010
    how short is too short for necks?
    Been lurking for a while and dreaming of buying a CNC machine for guitar builds. I searched a bit and can't find an answer to this question, so thought I would make it my first post.
    If I bought a table with an x-axis of 14", is it possible to route the backshape of a fender style neck in two steps? In other words, route roughly 1/2 the length, rotate/reposition the neck and then finish the rest of the neck? Or is it just too much work to do it this way?
    Thanks!
    Mar 2006
    127
    It's doable, it's just more work to fixture and program. Lots of people machine their necks in multiple setups. The more setups, the more likely you'll have to deal with transition marks etc. from part misalignment, though.
    Jun 2004
    38
    You could lay it out on a diagonal and machine, depending on the machines Y distance. a 14 x 14 table would allow machining on a 45 degree angle of about 20 inches, still probably not enough for a guitar neck though.
    This is the method I use to machine bass necks on my machine, as opposed to re-referencing my stock on one axis.
    To figure out maxium diagonal distance, take the sqr root of (Xsquared+Ysquared)
    Oct 2010
    Quote Originally Posted by Drassk View Post
    Thanks. How does one handle the transitions in the CAM software? Can you 'pause' the program midstream to reposition the piece or do you need multiple programs, one for each position?
    35538
    Multiple programs.
  1. Short Program
    By Geof in forum Haas Mills
    Last Post: 12-18-2009, 02:45 PM
  2. Life is too short
    By CNCRob in forum Community Club House
    Last Post: 02-22-2009, 04:56 AM
  3. Short on Variables
    By hydrospin01 in forum Fanuc
    Last Post: 02-14-2008, 02:03 PM
  4. A short cut is not always the best way!
    By planescott in forum Mach Software (ArtSoft software)
    Last Post: 03-13-2006, 03:58 AM
  5. Short G1 ignored in ver 14.7 CNC Pro
    By HuFlungDung in forum CamSoft Products
    Last Post: 10-13-2005, 04:05 PM
