587,744 active members*
2,895 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko 201 and Steppers
Results 1 to 3 of 3
    Dec 2004
    11
    Unhappy Gecko 201 and Steppers
    Iam a new guy on the block I built a controller using a campbell design breakout board, 3 Gecko 201,8 lead stepper motors input voltage is 36 volts,I thought when you turn the power on to the controller the steppers lock up,mine do not there is a very small amount of lock up I still can turn the shaft by hand I tried everything I know is there someone who can lead me in the correct direction.
    Jun 2005
    138
    It sounds like you forgot to solder in the pull-up resistors ("current-set resistor") across terminals 11 and 12 of the Gecko connectors. What is the per-phase amperage of your steppers? The resistor to use will be that number is set by the equation R (in kilo-Ohms)= 47*I / (7 - I). It's all in the Gecko manual that you can download from their website, on page 3. http://www.geckodrive.com/downloads.aspx
    Feb 2008
    243
    I think you miss wired the stepper motor. What make and model number is it?
    I can help you with getting it wired correctly.
    dan mauch
    Camtronics, inc. -- CNC with Dan Mauch
    [email protected]
    low cost cases for Gecko products.
    Kits and assembled systems.
    Quote Originally Posted by BAM View Post
  1. BP Steppers and Gecko Settings
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2010, 04:18 PM
  2. Steppers for Gecko 540
    By firestorm1284 in forum Benchtop Machines
    Last Post: 02-21-2009, 07:35 AM
  3. Want Gecko Drives for Steppers but Need Help
    By wganders in forum Gecko Drives
    Last Post: 12-05-2008, 02:16 AM
  4. wiring steppers/ gecko 201
    By littlebear in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-08-2006, 04:26 PM
  5. Gecko 201 for my steppers?
    By snaggletto in forum Gecko Drives
    Last Post: 02-28-2004, 05:22 AM
