587,138 active members*
3,792 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Info Required - M49SP-2K stepper motor
    Apr 2007
    25
    I stripped a HP laserjet 1010 printer and got this stepper motor out of it.
    Its a MITSUMI M49SP-2K LF 7.5 degree step
    I would like to know what type of motor is this and how do I build a controller for it.
    This is my first build.
    I want to build a small plotter
    http://i234.photobucket.com/albums/e...9112010464.jpg
    http://i234.photobucket.com/albums/e...9112010463.jpg
    http://i234.photobucket.com/albums/e...9112010462.jpg
    This is the info i got about the motor
    SPECIFICATIONS
    Stepping Motors
    Items M49SP-2K
    Rated Voltage DC 24V
    Working Voltage DC 21.6~26.4V
    Rated Current/Phase 1A(PEAK)
    No. of Phase 2 Phase
    Coil DC Resistance 4.6Ω
    Step Angle 7.5°/step
    Excitation Method 2-2 Phase excitation (Bipolar chopping driving)
    Insulation Class Class E insulation
    Holding Torque 134mN·m
    Pull-out Torque 100mN·m/1100pps
    Pull-in Torque 102mN·m/250pps
    Max. Pull-out Pulse Rate 2150pps
    Max. Pull-in Pulse Rate 430pps
    May 2005
    1397
    Interesting connector... I guess that is a 4 wire motor?
    Apr 2007
    25
    it has 5 wires.
    is it of any good?
    should i just put it in the "someday" box?
    thanks
    May 2005
    1397
    Seems like it would be good enough for a small plotter...
    To figure out which wire is which, you might read this web page:
    Stepper Motor wiring
    And if you run 24 volts, 1 amp, that is 24 watts so it should pull a pen around at quite a few inches per second given a good quality lead screw and low friction bearings.
    The Linistepper driver would run it nicely, and give you good resolution.
  1. Need more info on Stepper motor
    By cnc1965 in forum Stepper Motors / Drives
    Last Post: 09-09-2010, 11:12 AM
  2. Info for a technical paper about stepper motor applications
    By Jef Peeters in forum Mentors & Apprentice Locator
    Last Post: 12-08-2008, 06:59 PM
  3. Info required
    By jamiefegan in forum MetalWork Discussion
    Last Post: 06-16-2008, 10:52 PM
  4. LiniStepper? Retrieved Stepper motor info.
    By pksdms in forum Stepper Motors / Drives
    Last Post: 10-18-2007, 02:12 PM
  5. Need info on stepper motor
    By biplanefan in forum CNC Wire Foam Cutter Machines
    Last Post: 04-27-2007, 11:58 PM
