588,211 active members*
3,734 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Help! New to 10M on Mycenter 1
Results 1 to 7 of 7
    Jun 2006
    6
    I recently acquired a MyCenter 1 with a fanuc 10M control. Everything seems to function correctly except that I cannot get it to work on automatic modes. In manual, I can get the spindle working, toolchanger, all axes, etc; but there is a "stop" next to the mem/edit/mdi/jog on the control, and when I cycle start in mem mode I get an sr592 "End of record error." Does anyone have any insight into this issue? I've ran later fanucs, but never any of the earlier models and its been a while at any rate. Any thoughts would be greatly appreciated.
    Thanks,
    Mike
    2932
    According to my 10M manual there's an EOR specified half-way through a block. If I remember correctly, EOR is a % sign. Do you have an M02 or M30 at the end of the program?
    Jun 2006
    6
    Actually I don't know. I just recieved the machine and was trying to run a program that was already in memory. I'll have to look at it shortly and see. Thanks for the reply though, I'll have to go look through the code more closely and see what I can figure out.
    -Mike
    Jun 2006
    6
    It has an M30 at the end. The program also seems to have extra EOB's on otherwise blank lines. I would assume the control would ignore them, but perhaps I'm wrong?
    2932
    Extra EOB's shouldn't cause a problem. You don't see a % sign anywhere?
    Jun 2006
    6
    There is the standard % at the end after the M30, but not one at the beginning. I can't see how to enter one on the control if I wanted to however.
    -Mike
    2932
    How about if you create a simple program in memory and try running that?
    O1234
    M3 S200
    G4 X10.
    M30
  1. Kitamura Mycenter 2xi
    By centertoolco in forum Kitamura
    Last Post: 01-13-2024, 06:06 PM
  2. KITAMURA MYCENTER 1/485
    By Antonio Arguijo in forum CNC Machining Centers
    Last Post: 06-08-2011, 04:09 PM
  3. Kitamura Mycenter
    By cdlenterprises in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2007, 05:25 AM
  4. Kitamura Mycenter 3B
    By sebaja in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2007, 11:22 PM
  5. Kitamura Mycenter 0
    By inertialabs in forum Shopmaster/Shoptask
    Last Post: 01-16-2007, 03:47 AM
