588,159 active members*
4,740 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Need help again - engraving issue
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Sep 2009
    318
    It is not stored in the XML file.
    The SprutCAM.dsk file load the defaults. In this file mine is set to load SprutSetup.cfg as my config file.
    Configuration=$(PROGRAM_APPDATA)\SprutSetup.cfg
    Inside my config file (SprutSetup.cfg) I have import tolerance set to .0001
    <Import_CrvImportTolerance>0.0001</Import_CrvImportTolerance>
    Yet when I start SprutCAM and go into setup and even though it lists SprutSetup.CFG as the current file. The import tolerance is set to .01
    If I then tell it to load SprutSetup.CFG the tolerance is changed to .0001
    So there must be a bug in the program.
  2. #22
    Jun 2006
    3063
    Thanks for the correction. Hope I didn't steer anyone wrong for too long.
    Do you have more than one "SprutSetup.CFG" file on your system?
    Mike
  3. #23
    Sep 2009
    318
    Nope and just to make sure I was looking in the correct directory I had it create a new file and if you delete the default one it will recreate it in the same directory. sO I know I am in the correct directory it just does not seem to parse the config file correctly.
  4. #24
    Dec 2009
    48
    SprutCAM 7.1.2 nightly build
    Quote Originally Posted by Live View Post
    Hello, Tim.
    The problem with intolerant engraving toolpath on small parts will be solved in some of the nearest nigtly builds. I'll post a link to it, when it'll be available.
    http://download.sprutcam.com/index.p....2.39822rc.exe
  5. #25
    Sep 2009
    318
    So far that looks MUCH better. I also like how it is much more detailed on the simulation. When doing engraving is there a way to make the tool centered on the edge or do you have to set a negative stock? Also when there is nested edges what is the easiest way to keep the tool from cutting between them? Like this..
  6. #26
    Dec 2009
    48
    Quote Originally Posted by compunerdy View Post
    1. We will add the base surface feature into 2d contouring operations in the nearest future.
    2. I am not sure, the image looks like a bug. Could you post the project please?
  7. #27
    Sep 2009
    318
    Here you go..
    sprutengrave.zip
  8. #28
    Dec 2009
    48
    Here you go..
    sprutengrave.zip
    It's not a bug, it's just a "Short link".
    Open the operation parameters panel -> Transition, and set the <Short link> option to 30% of the tool diameter instead of default 300%,
    or set the <Stepover type> on the same page to <Via safe plane> instead of default <On surface>.
  9. #29
    Sep 2009
    318
    That fixed it..thanks again.
  10. #30
    Sep 2009
    318
    Double post..
    I had to come back to say THANK YOU!! once again and say that the engraving job worked flawlessly and this new version is MUCH better than the last one I was using. No more lockups even!!
    Thanks!!
  11. #31
    Dec 2009
    48
    Engraving without offsetting
    In the latest builds (http://download.sprutcam.com/downloa....2.39989rc.exe) we have added the <Contact Point> option into engraving operations.
    If you want to trace contours without any offsetting in an Engraving operation, just set the tool contact point to the tool tip.
  12. #32
    Sep 2009
    318
    Downloaded and seems to work great.. much easier with that option.
Page 2 of 2 12
  1. Little issue with G10
    By Myrmidon in forum Fanuc
    Last Post: 03-16-2015, 02:34 AM
  2. VF3 issue
    By driver1234 in forum Haas Mills
    Last Post: 03-11-2010, 06:11 PM
  3. will this be an issue?
    By stk2008 in forum Stepper Motors / Drives
    Last Post: 09-17-2009, 04:35 PM
  4. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  5. THC Issue
    By Aldoseri in forum CamSoft Products
    Last Post: 01-31-2006, 11:33 AM
