588,204 active members*
4,078 visitors online*
Results 1 to 8 of 8
    Aug 2004
    210
    More Inputs please ??
    Hello everyone
    what is the best solustion for more then 8 inputs for my router table ?
    I have 3 gekodrives driving 3 stepper motors and i would like to add a mpg and encoders on my steppers ??
    Thanks for all your help
    Big
    35538
    Another parallel port.
    Why do you want to add encoders? There's no benefit to using encoders with steppers.
    Aug 2004
    210
    Hello
    Adding a other parellel port will only give me 8 more is thare somting that will give me maybe say 20+
    Jan 2006
    738
    You might try these guys....
    anything i/o
    Trying to do an encoder on a stepper can be troublesome, especially using the parallel ports as input. Part of the reason is that the parallel port must constantly monitor the encoder at a very high rate for any change on it's output.
    If you really need closed loop control, then you should consider switching to servos with encoders and servo drivers like the Gecko G320 or G340, or a full blown motion control system such as the Delta Tau PMAC.
    Delta Tau - PCI
    Steve
    Aug 2004
    210
    Hello Steve
    that is exacly what i was looking for I wonder if this board will work with mach3 ??
    7I61 FPGA based High Speed USB Anything I/O card
    Do you think that I/O card would be fast enough to run encoders ??
    I would like to keep my steppers and my gekos just cuz i got them for almost nothing
    Big
    Jan 2006
    738
    Big,
    I don't think Mach has a plugin for the anything IO's. EMC does for some of them.
    Mesa Electronics Anything I/O boards (plus all the Servo & Stepper Daughter Boards, etc) Mesa Electronics
    The Anything I/O boards are all based on FPGAs, so can be loaded with different firmwares at the start of EMC.
    Firmware defines the number of encoder, PWM, stepgens and General Purpose IO.
    5i20, PCI, 200K gates, 72 I/O pins
    5i22, PCI, 1.0M or 1.5M gates, 96 I/O pins
    5i23, PCI, 400K gates, 72 I/O pins
    4i65, PC-104/Plus?, 200K gates, 72 I/O pins
    4i68, PC-104/Plus?, 200K or 400K gates, 72 I/O pins
    3x20, PCI-Express, 1.0M or 1.5M or 2.0M gates, 144 I/O pins
    Just load the mesa fpga with the appropriate firmware to handle your encoders and steppers......
    Do you already have a machine built that you are having problems with tracking on? Just wondering why you are needing encoders? I've been running a stepper machine for a couple of years now and the only time I have an issue with it skipping steps or hanging is if I run the motors up into their midband resonance range. And encoders would not help there except maybe to stop the machine because it lost track. If a stepper is missing steps because it's running too fast, you can't make it catch up by trying to make it run faster. I've seen comercial stepper driven machines ($40,000 range) without encoders that run just fine as production machines 8 hours a day for years.
    Steve
    Aug 2004
    210
    I just wanted encoder as insurance i think i will just run 2 or 3 peralle port
    35538
    Mach3 only supports 2 parallel ports.
    A guy on the Mach3 forum has a Mesa card plugin, but it hasn't been released yet.
    You might want to look at a Pokeys.
    But I think you'll need to use the parallel port if you want real time encoder inputs.
  1. Need Help please with Inputs and Outputs
    By MMT in forum Mach Software (ArtSoft software)
    Last Post: 01-30-2010, 12:57 PM
  2. How to see which inputs are active in emc2
    By roamingdrone in forum LinuxCNC (formerly EMC2)
    Last Post: 09-04-2009, 04:51 PM
  3. VSD-E HOME INPUTS
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2009, 02:28 PM
  4. inputs outputs
    By sintratech in forum Machines running Mach Software
    Last Post: 04-01-2007, 08:17 PM
  5. Inputs/Outputs
    By UKRobotics in forum CNC Machine Related Electronics
    Last Post: 08-03-2006, 03:52 AM
