588,457 active members*
5,287 visitors online*
Results 1 to 6 of 6
    34
    Potential Issues
    I have recently purchased a cnc mill that came with a Mitsubishi Freqrol-A024 Variable frequency drive (2.2 KW output) to control the 3 horsepower 3 phase spindle motor. Now i know that most VFD's can be run on single phase power and that it will output around 2/3 the total rated power of the motor but i'm wondering if there are any potential problems with running it on single phase instead of 3 phase.
    Basically im wondering if:
    1.) will ANY vfd will run on single phase or is there a chance i will blow it up?
    2.) would i be better off running the vfd from a surplus 3-phase motor that tacks on the 3 leg of power - even if i didn't balance the phase and voltage outputs (ie: if i made a rotary phase converter with a pull cord and a normal motor and then just ran this straight into my VFD). Would this be better or possibly worse without the voltage and phase being regulated?
    Thanks.
    Mar 2004
    1543
    I'm running botha monarch 10EE and an Excello CNC nmill on VFD with single phase. No problems.
    I was told that the derating isn't even necessary in the smaller drives. My 10EE is a 5 hp VFD and a 5 hp spindle.
    Karl
    Nov 2004
    446
    Three Phase is almost always better than single phase..
    Get / Make a phase converter... There maybe other things you will need it for also.
    Just my 2 cents.
    Murphy
    34
    So does this mean that running any small vfd on single phase power will not damage it?
    Dec 2003
    24221
    Most VFD have plenty of protection in them, some (vary rare) need three phases to run, All the mitsubishi I have used you can run on single phase up to around 5hp.
    Most have a preference on the input terminals for the single phase input, on mitsubishi it is R S of RST terminals.
    Al.
    Albert E.
    34
    Thanks for the help. i think i might end up going with a rotary phase converter becuase i need to run some other 3 phase machinery
  1. encoder issues
    By rutexus in forum Servo Drives
    Last Post: 05-22-2006, 12:49 AM
  2. Rutex Servo issues.
    By ty1295 in forum Servo Drives
    Last Post: 05-28-2005, 05:10 AM
  3. Drive issues already!!!
    Last Post: 09-03-2004, 01:49 AM
  4. Soft Wear Issues
    By bean7795 in forum Uncategorised CAM Discussion
    Last Post: 04-16-2004, 04:09 AM
  5. ACAD 2002 issues????
    By DanFri in forum Autodesk
    Last Post: 07-02-2003, 07:16 PM
