588,407 active members*
5,746 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Help identifying an old stepper driver board
Results 1 to 3 of 3
    Dec 2010
    I recently got ripped off by taking remote delivery of a cute little Sherline CNC retrofit. The seller (who I never met) was supposed to provide docs etc but just took my money. I got the mill working but just blew it up a little tying to straighten out the wiring mess that would have blown up on its own if i didn't do it first. I have no idea who made the 4 axis bipolar stepper driver board. it seems to be a chopper and maybe microstepping. my guess is that it is 10 to 15 years old???i need to identify it so i can figure out a few switch lines. some lines were jumped together and i accidentally lost track of which ones were. there is no identification on the silk screen or the copper on either side of the board.
    May 2005
    1662
    It could be a Xylotex.
    The picture looks very similar except for the fuse(?) by the power plug.
    Dec 2010
    thanks that sure looks like what i have
    thanks for the speedy reply. the four axis version is what i have. the only difference is the cap (not a fuse) where something else is in the current doc. with your identification i was able to determine that nothing is wrong with the board. the wires i accidentally cut were not needed anyway as they were just redundant common leads for the step and dire signals. the guy who set this thing up was a moron and a slob. i accidentally fried something trying to figure out all the same color leads and sloppy soldering. now i can concentrate on what is probably the problem, a burned out buffer chip on the breakout board or maybe the parallel port on the computer.:cheers:
  1. Stepper driver, breakout board problems
    By dougie329 in forum DIY CNC Router Table Machines
    Last Post: 08-16-2011, 10:59 AM
  2. Wiring Stepper, driver and breakout board
    By bdrotaru in forum Stepper Motors / Drives
    Last Post: 02-26-2011, 06:30 PM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. univelop stepper driver board
    By vicsrc in forum Stepper Motors / Drives
    Last Post: 03-17-2009, 01:51 AM
  5. Stepper motor A vs driver board A
    By tsknutsen in forum Stepper Motors / Drives
    Last Post: 03-14-2009, 02:41 AM
