587,177 active members*
3,572 visitors online*
Results 1 to 14 of 14
    Jun 2010
    Cutting aluminum
    I'm after some advice with milling aluminium
    Firstly I have a small Taig desktop mill
    The parts I make are made from aluminium plates ranging in thickness from 3mm to 12mm
    For the 3mm parts I cut 3mm in one pass the thicker parts I mill multiple depth passes, essentially I do a lot of slotting
    Should I be using endmills or slotdrills?
    Should I get a tool specifically made for aluminium?
    For the specific tools can get "Solid carbide K grade slotdrills" or "Solid carbide fire coated endmills"?
    I currently use a HSS 2 flute 6mm end mill 6,000rpm at 24ipm for most of the work I do
    Jul 2005
    12177
    What you need is a two fluted high helix micrograin carbide end mill. Here in Canada two makes are Garr and Gorilla but there are many others. The high helix which acts to pull the chip up out of the cut, micrograin carbide can be sharpened to a very keen cutting edge and two flutes give good chip clearance.
    You don't mention whether you are using coolant or lubricant, certainly you should be. Flooding with collant could be messy but a mister could spray a small amount of coolant on the tool and this will help immensely.
    With a 6mm cutter running at 6000 rpm in 6061 aluminum alloy with coolant you should be able to cut at least one diameter deep at the feed you are using.
    Jun 2010
    I'm using flood coolant
    I dont know about micrograin carbide but I can get solid carbide
    What is considered a high helix angle?
    Jul 2005
    12177
    45 degree helix or somewhere around that.
    This company is the distributor for GARR tools down there.
    SEI Carbide Australia - Tungsten Carbide, CBN, and Diamond cutting tools.
    Jan 2007
    1389
    Garr is what I use, the smallest coated endmill for alum cutting they make That I can get ahold of here is 3/8. I am told a 1/4" is suppose to be avail this coming year.
    with a 1/4" (close to 6mm)garr standard 2 flute ball non alum cutting normal helix I run 8500rpm at 100-115 ipm with a .035 step over at up to .175 depth of cut. it screams and its loud. but it works and last quite a long time.
    Delw
    Jun 2010
    What depth can you cut slots with this tool?
    As I cut more slots then profile
    Jan 2007
    1389
    as deep as the endmill has cutting flutes, you can get extended ones pretty long
    Jun 2010
    Really... If the tool had 20mm flutes I can cut a 20mm deep slot in one pass with this tool?
    Jul 2005
    12177
    Quote Originally Posted by chris123 View Post
    NO!
    You can get that deep in multiple passes. In aluminum for instance, I would go down about 1mm per pass at 10,000rpm and a feed of maybe 50mm per minute (although that feed may be a bit high, I am not sure).
    There would be considerable deflection so if you were cutting a 6mm wide slot it would be wise to use a tool about 5 or 5.5mm diameter and offset it to get the correct width.
    Jun 2010
    I use HSS at 6,000rpm at 600mm/min and go 3mm deep
    Jan 2007
    1389
    Quote Originally Posted by Geof View Post
    NO!
    NO way not in one pass,
    Have you ever done machining before? I assumed you did thats why I gave you the info I gave, sorry if I confused you.
    Delw
    Jun 2010
    I've been machining for about 6 months
    I also use flood coolant
    Dec 2010
    For aluminium use 2(3) flutes HSS or Solid Caribide Uncoated. With tool diameter 10mm you can go even 6mm down at 9800rpm and 1000mm/min, for 6mm cutters I use 9800 and 1000-1500mm/min and depth of cut 4mm. With strong coolant cutting really nice.
    Jan 2011
    i would like to know some information about the CBN tools and suggestion others tools for cutting my materials?
    is tat possible by using CBN face milling to cut my material on CNC?
    Material details:
    Alumina ceramic
    purity:99.0%
    thickness:10mm
    net weight:780g
    best regard,
    Mr Vincent Ting
  1. RFQ - cutting 1 5/8 aluminum rod
    By jhuebbe in forum Employment Opportunity
    Last Post: 07-24-2009, 03:33 AM
  2. Cutting .250+ Aluminum
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 06-04-2009, 06:28 PM
  3. Cutting Aluminum
    By jeffmorris in forum MetalWork Discussion
    Last Post: 02-27-2008, 11:14 PM
  4. Cutting Aluminum
    By darylprice in forum DIY CNC Router Table Machines
    Last Post: 07-03-2006, 04:51 PM
  5. Cutting aluminum
    By rocks101 in forum DIY CNC Router Table Machines
    Last Post: 02-27-2005, 08:29 PM
