Do it in the engage/retract tab.
You can easily get the cutter to start in the center be using most any of the functions there (I prefer radial but you may need to use a straight plunge due to the geometry).
You may need to change the start point of the region out of that tip to get it to work.
I would do this machining OP exactly as you have.
