588,516 active members*
5,913 visitors online*
Thread: Autocad 2011
Results 1 to 9 of 9
    Mar 2007
    398
    Autocad 2011
    Hi all I thought I would give Autocad 2011 demo a go and so far its awesome gutted though as I can never afford it after 30 days).
    But any who I have a problem
    I am trying to create a circle where you can see the red circle I did in paint shop.
    I cant seem to get there as the WCS is wrong all so I cant get it to snap to the centre on the line you see the dot on
    Please help.
    35538
    Assuming you want a hole going through, here's what i'd do.
    I'd draw a line across that area, between the midpoints of the 2 vertical square corners. Do the same on the opposite side, and draw a line connecting them.
    Then just make a cylinder with the correct diameter, and long enough to go through, align it to the line, and subtract it.
    Mar 2007
    398
    Wow GER21 you get every where mate I didn't expect to see you in this thread category.
    Unfortunately I have tried that but it wont align the circle to the radius plain just side on.
    Yes I want to bore the hole out to the other side but like I said every time I place a circle even with the method above it puts the circle flush with either the X or Y axis I want it 45 degrees between the two as you can see in pic.
    Just to show you (sorry not on main pc now)
    even doing it the way above it all ways puts the circle in the position of the bold red circle.
    P.S
    Thanks for the reply.
    35538
    upload the model in 2007 format and I'll show you what I'm talking about.
    Mar 2007
    398
    Hi again damn I cant at the moment as im not near me main pc.
    Will the demo allow me to save? as I did not save it but I can create it again easy enough up to the point of creating this circle :P.
    Would you be able to show me with the crappy picture above?.
    Thanks again GER21
    35538
    I don't usually move my UCS. I'd just create a cylinder, and align it to the line through the center of your part. Use the Align command.
    Mar 2007
    398
    I cant seem to figure it out no matter what align tool/snap to I use it cant get it to work.
    35538
    You have you're line going through the middle. Now, create a solid cylinder, longer than it needs to be, with the correct diameter.
    Type ALIGN.
    Click the center of one end of the cylinder, then one end of the line, then, the other end of the cylinder, then the other end of the line, then hit enter, 3 times I think, and the cylinder will be where you want it, ready to subtract.
    Mar 2007
    398
    Wow great thanks GER21 I will give this a try as soon as I get on me main pc again.
    Thanks you have all ways offered me solid advice.
    EDIT
    Like I said all ways solid advice thanks very much
  1. Just FYI on Alibre 2011
    By cjdavis618 in forum Uncategorised CAD Discussion
    Last Post: 12-02-2010, 11:11 PM
  2. Autocad 2011-undo & redo zoom
    By Patternboy in forum Autodesk
    Last Post: 11-04-2010, 01:20 PM
  3. Help: Autocad 2000 (Autocad Error aborting)
    By Holmes_ca in forum Autodesk
    Last Post: 05-07-2010, 02:07 PM
  4. Does anyone have information on a CXR 2011?
    By Bill Gillen in forum DIY CNC Router Table Machines
    Last Post: 11-28-2006, 10:04 PM
