hi I have a okuma howa 3VA whit fanuc 10M and i lost the parameters
by replace the batery, i have the parameters by tape but i don´t know
how to charge it. does any one can help me !!!!!!!!!!
tanks a lot
tanks a lot
I have fanuc 6mb parameters and maintenance manual.
If you want to get
Give me([email protected]) your e-mail address
Good luck
For a Nominal Fee, I can convert your Paper Tape to a PC friendly File and also supply a print out of the data.
PM me for more info.
Versa
On the standard 6M control there was ONE set of Offsets 01 to 99
The same offset data was used for Both, tool Lengths, and tool Radius
If your tool changer has 20 tools, use offset numbers 01 to 20 for the Lenghts, and offset numbers 31 to 50 for the tool radius.
add 30 to the tool number for the radius offsets
To enter a value in the offset, you place the cursor on the offset number,
Enter a P then the value you want to enter. press input
In your program you use G43 H01 look up the value in offset 01
G41 or G42 D31 look up the value in offset 31
Hi I´m Guillermo Meneses from Mexico , I have a problem whit my
cnc OKUMA HOWA 3VA it have a control FANUC 10M and i lost
the parameter by error at replace the batery, i apreciate a lot that
you send me a copy of your manual to FANUC 6M to try setup up
again my 10M
my email [email protected]
thanks a lot
Guillermo Meneses
what can i need to do that, and how can i download the parameter to my
FANUC 10M
[email protected]
Hi I have an old Mazak H20 Machine with a Fanuc 6MB control,
I had problems and lost all the parameters, I just reload them but know when I try to send the Y axe Home itruns like crazy to the limit switch.
Is there a parameter to control that?
How many axis have your machine i have parameter for sofia machining center 5 axis and makino horizontal 3 axis, and mazac horizontal 4 axis.
Pls help me,
I need Fanuc 6M modelB PC parameter and Mainternance Pls send me by email: [email protected]
How can i download the parameters to my cnc OKUMA HOWA 3VA
i don´t know how to do that
i have a parameter tape
the reader is like this
Can anyone tell me where I can get the parameters for fanuc O-TD all. Help.
Email [email protected]
Anyone can help me change character display in my Fanuc 6M?
All characters are in Japanese, and I want to convert it into English.
Please, anyone knows the parameter # for the convertion of language with this system? Please, help me....
Hello!
I have a John Ford machine Fanuc 0M command, and is working well. Would you please tell me how to backup all the important data (parameters, macro variables, offsets...) so that in case of a memory reset, to be able to do a data restauration.
Thank you!
I am in a similar situation in that I need to read parameters from my tape. My SETTING page has INPUT DEVICE 2 = 1, and I need to change it to 0 as you described.
However, I can't figure out how to change it! I move the cursor over to the proper line, press 0 and INPUT, but nothing happens. I read somewhere that I need to be in MDI mode to do this, but I am unable to get into MDI mode because it requires that my axes are zeroed, but my Z axis won't move (that's why I'm trying to reload the parameters in the first place).
Does anyone know how to change the INPUT DEVICE settings?
You must be in MDI mode, and the memory protect key switch must be off. Display the SETTING page and cursur to the INPUT DEVICE 2 bit. Then, press the letter "P", then press INPUT. That should do it!
Thanks Dan for the super quick reply!
I will try that, but right now I can't get into MDI mode. The machine is a Wiedemann Centrum 1000. When I press the MDI button, I get an alarm message saying ZERO NOT SET. This is because I am unable to zero the T axis.
Is there a workaround to get into MDI mode without zeroing the axes?
Is your machine punch press. Push emergency then do it
Grass is always greener on the other side of the hill
Thanks - I have tried two different ways to put the machine into emergency mode, however it still will not go into MDI mode.
I once managed to trick the machine into thinking that the turret was zeroed, but I cannot seem to duplicate it.
Any other ideas?
in the back cabinet you will find th OD board on this board you will find the emergency state parameter switch(esp)
this switch will allow you into MDI mode
Hi All,
We have a Bridgeport 320H with a Fanuc 6MB controller. We have lost our parameters & are unable to run the machine.
Could you please help us in getting the parameters. You may email us at [email protected]
Thank in advance.. Regards
