CNC Write is now ready to download. Get your free demo at http://cncwrite.com
CNC Write is a brand new engraving program that is designed to make fast work of common engraving operations. The interface is simple and easy to use. No hunting through cryptic menus for options. If you are familiar with writing your own G-Codes, it is easy to make custom font's and symbols to use in CNC Write. CNC Write was not intended to be used for fancy engraving on signs and plaques, However by designing your own fonts and building a font file, that type of work can be done with CNC Write.
There are two versions, Standard Mill mode and Integrex. The only difference is the Integrex version adds all the features you need for cylindrical interpolation on the Mazak Integrex. Integrexman at integrexmachinist.com can answer your questions about the Integrex modes.
I haven't decided on a price yet but I can say that the highest it will be is 300 for Mill version and 400 for Integrex. It will very likely be less than that though.
The only difference between the demo version and the registered version, is the demo version will randomly replace letters with an 'X'. Once you purchase a registration key, and register the program, that will no longer happen. Please note that the 'X' will often be a different width than the letter it is replacing, this may cause some overlap with that X and the next letter. This is not a problem with the registered version.
If demand is high, many new features will be added in the future. Give the program a try and let me know what you think and what else you would like it to do.
Chris W
