Any help with the parameter settings would be appreciated.
What control do you have?
Are you trying to increase or decrease the rapid speeds?
What axis are you trying to change?
It is a MF-T6 and I want to speed them up. I have tried to bump up the rapid traverse values in the parameter setting and it kicks out the servo and gives an alarm.I know most mori turning centers are capable of 196 ipm in x and more than that in z and we are nowhere near that.
First, sl65 is a old big machine. You need to first check the parameters against the factory parameter list. If they are different, put them back to factory. If it kicks out your servos then, you have other major issues. My two guesses are ther was something mechanical wrong, so someone slowed them down to band aid it,,or the door interlock is not right so it's putting the rapids at half speed. These were never super fast machines though.
