587,997 active members*
1,987 visitors online*
Results 1 to 3 of 3
    Feb 2010
    230
    G codes M codes Mach3
    I finally have my FLA-100 CNC machine finished and purchased Mach3.
    Everything on the machine works but now I need to think about Cam
    software or something like Vcarve Pro. I need an experts knowledge before
    I purchase one of these software packs.
    My CNC router is in the basement and my work machine is upstairs.
    Am I correct in assuming that I can install Cam or Vcarve on the upstairs machine, create my drawings and then output the drawing to a file which has the gcodes in it and then transfer the file via a usb thumb drive to the Mach3 machine in the basement? I'm sure that to most of you this is a basic question but I am confused and need to make sure that this will work before buying the software. Thanks!
    Regards, Carl
    May 2004
    162
    Wink Files
    Quote Originally Posted by eaglezsoar View Post
    That's the way I do it and it works every time!!! Vcarve Pro is a very nice program :cheers:
    35538
    Yes, that will work.
    I have my machine on my home network, and just copy the files right to the machine from inside the house.
  1. Cant load up G codes in Mach3
    By hugo carradini in forum Mach Software (ArtSoft software)
    Last Post: 01-13-2014, 08:57 PM
  2. Mach3 M codes?
    By DNA Robotics in forum Uncategorised CAM Discussion
    Last Post: 07-28-2013, 11:29 PM
  3. G codes and M codes for Mazak Quick Turn T-2
    By sauli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2011, 05:22 PM
  4. Need full list of G CODES AND M CODES FOR FANUC 21I
    By SonnyTees.com in forum G-Code Programing
    Last Post: 02-23-2010, 05:27 PM
  5. M-codes and G-codes 4 Matsuura ES-1000V
    By maximusek in forum G-Code Programing
    Last Post: 11-27-2007, 01:41 PM
