587,651 active members*
3,601 visitors online*
Results 1 to 6 of 6
    Oct 2008
    12
    esab burny 2.5
    I need some advice please.
    I own a esab burny 2.5 gas profile table and want to connect it via the rs-232 port to my computer. I have a demo of Sheetcam (wanted to try b4 i buy) for creating the cnc code but am unsure of how to get it to talk to my burny 2.5.
    From the burny website it states
    "CLINK is another special communications protocol which allows the 2.5 to send and receive part cutting programs from a remote computer via commands sent through the RS-232 port"
    can some please advise on what i need for my sheetcam code to talk to my burny 2.5.
    from what i have read i think i need something like aggsoft DNC Precision but i am unsure. DNC Precision | Compare features | AGG Software
    Any advice would be brilliant.
    Many Thanks
    paul h
    Apr 2009
    15
    most full systems have a dnc link program included however as you are using a demo version it will not
    before you even start attempting to connect to the burny you need to know
    if the sheet cam is producing the cnc file in a format the burny will understand
    ie does it have a burny post processor.
    the format should be either essi or word address
    you also need to check if the cut on codes etc correspond to those the burny uses.
    there should also be a % at the beginning of the program and a 99 or an M30 at the end
    if this is the case from a quick look at the website it appears the agg software will do the job
    next you need to make up a serial lead between the burny and you pc
    i prefer x on /x off as it only needs 3 wires and is easier to fault find on
    the diagram for this is in section 5 of your manual
    load the agg software on to a pc with a serial port - which are fairly hard to come by these days
    you now need to match the serial port setting on the burny with those of the agg software
    the burny settings are in SD50 it is a 4 digit code which equates to handshake type baud rate etc
    you may be able to "point" the agg software to the folder in which you are going to store your cnc files
    note all files need to be 8 digits long so you have to have leading zeros and can give the cnc file names
    once you think you are ready make sure the cable is connected
    go to load shape
    scroll to load from rs232
    type in the number of your lovingly created part
    press enter
    loading 0 with a flashing * next to it will appear
    if all is well the number will increase until the shape is down loaded
    then press recycle and run the shape as you would normally
    if it does not change all is not lost you may be able to manually select and send the file via the agg software
    hope this helps
    Paul
    Oct 2008
    12
    Thanks Gillyshank for taking the time to reply sorry for the delayed response.
    You suggest "make up a serial lead between the burny and you pc" i like this as i have been in contact with ESAB who want to charge £465 for 100 m DNC cable and associated line drivers . Have you any suggestions as to where i can get the fittings ?
    Thanks again
    Paul H
    Apr 2009
    15
    Hi
    RS components or Farnell will supply the bits you need
    a burny will work up to 100m without a line driver - although these do give protection against " noise" damaging your RS232 / serial ports
    for trial purposes I would make up a small lead and run it from a laptop
    then you can unplug it when you are done
    regards
    Paul G
    Oct 2008
    12
    Hi Paul G
    Thanks for pointing me in the right direction. Hopefully i will get up and running soon
    Paul H
    May 2012
    BURNY 2.5 PINOUT CABLE
    Hello!!
    Can any body tell me if this pinout is correct?
    Attached Files Attached Files
  1. ESAB Picorex PXA 15
    By taaniel1986 in forum Want To Buy...Need help!
    Last Post: 09-26-2014, 06:18 PM
  2. ESAB MEF 44N w/ LAI 400
    By Alex S.A in forum Welding Brazing Soldering Sealing
    Last Post: 10-24-2010, 07:53 AM
  3. Esab Shadow
    By TripleTFab in forum Waterjet General Topics
    Last Post: 03-10-2010, 05:47 PM
  4. Hypertherm or ESAB
    By gfelippo in forum Torchmate
    Last Post: 11-05-2008, 08:36 PM
  5. ESAB controller
    By canuckman in forum Waterjet General Topics
    Last Post: 10-23-2008, 11:28 AM
