I used to have tons of dumb boss stories, but my hypnotist erased them from my memory for me. It was the only way to cure my ulcers.Originally Posted by WayneHill
Well, I am not sure...but the guys who are actually trying to do this job approached me with a question about machining this with triangular or diamond-shaped inserts...with small tip radius, of course (0.4mm or similar).Originally Posted by WayneHill
Originally Posted by lerman
Actually, I have no idea......this is not a job that I should do, but just make a suggestion how to write a program for it and whether the machine like a plain CNC lathe (we were talking about HAAS SL-30 or similar) is able to do.
The screenshot that I've attached is there just for you guys to get an idea how the d**n thing should look like, it is NOT a screenshot of the actual model...I've made the model just to take that screenshot.
As far as I could understand, this thread is used in some kind of drilling heads for drilling through hard rock, very likely in oil industry, which could mean that the thing is HUGE. I guess that there is an original part available, but is either too expensive so they are trying to save funds or want to start a production of a reverse-engineered part for the market.
I apologize if I made you think that this is something that I should machine in my own shop or at work, it was not intentional. I am not going to make a penny out of this, but just saw this as an opportunity to learn something new.
Originally Posted by screensnot
I get your point, it is enough for one to just take a look at the pictures ghyman has attached...it becomes obvious.
Now I have, hopefully, understood at least the idea ghyman has suggested. However, what I thought at the beginning was to make a program that would guide the tool along the X and Z axes SIMULTANEOUSLY, with a feedrate calculated in a way so, at the end, a proper thread profile with an exact pitch would be obtained and the scallops would be avoided. If you take a look at the thread cycle (G76) there is no way to make a tool move along the X-axis while making multiple passes. That's why this task seemed like the one that can't be done.
Please take a look two posts up...I've explained that I have no idea about the actual dimensions.Originally Posted by ghyman
Sorry... must've posted b4 I saw your reply.
Yes you have, but just because I have not replied yet. Then I just did not want to write the same thing twice, so I asked you to see the reply I've written to lerman.Originally Posted by ghyman
G'day
Why don't you EDM wire cut a full form tool. It's only an idea
John
Nobody likes a showoff, oldjohn!Originally Posted by oldjohn
Actually, I'd done that on a daily basis several years ago when I was making a "magic thread form" for bone screws for a spinal implant company... it never dawned on me to do the same thing in this case!
I guess I've gotten so used to "creative" programming, that I forget the easy answers!
Here's an idea...send it to a thread grinder and let him worry about it.
If you will get the full profile, it's easy with the tools you have. Just cut the threads with the standard 55` or 60`, then use a formed cuttingtool to take care of the upper radius.
