As the title states, the table will not index. (This is the standard 1 degree indexing table.) No alarm is given. It just does nothing. Also, the LED indicator above the door that should show table index degrees and tool # is blank. The drive for the index motor (MV-4) has two red LEDs that are lit up. They are LED1 and TL. I do not know what these indicate. I was only able to verify that the incoming power is ok.
I'm suspicious of the M/T Controller as it has two LED lights that are flashing randomly. They are LD0 and LD1. They are both coming on and off, sometimes flashing quickly, sometimes staying on for a while. They also vary in brightness. Again, I don't know what these indicate, but the flashing doesn't seem right to me. Also, LD4 is lit, but this is on all the time.
Please let me know if you have any ideas on what I should be looking at. I'm more of a Fanuc guy, so this Mazatrol is a bit confusing to me. Thanks in advance.
