588,429 active members*
5,702 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Anyone using Genevieve straddle knurl?!?!?
Results 1 to 7 of 7
    Feb 2011
    Is anyone out there using a Genevieve compact straddel knurl on a swiss (slide)? I am considering purchasing one, but would like some feedback from someone using one. Thanks in advanced!
    Here is a link to what I'm taking about: Straddle Knurling Holders & Tools for CNC Swiss Machines
    We do an amount of small (.110Ø - .500Ø) stainless knurling and have not found a good consistant knurler that will work for us. We are currently using an eagle rock cut knurl, it does a fair job, but would like to find something better if possible.
    Aug 2006
    162
    yes, i use one however i use it tangent to the part as opposed to true straddle,
    we primarilly knurl aluminum and have had great success with this tool
    we have knurled tens of thousands of parts and have never had to do any thing to it as far as repair(still has original wheels) , and have seen only a few mistracks across all that time,
    Mar 2008
    443
    I haven't used one yet, but can offer this: I know the owner of and the people who work at Genvieve Swiss and know that they:
    1) Test the tooling they sell to be sure it works and meets their standards before they'll sell it.
    2) Stand behind anything they sell to make certain you are happy with it.
    You really can't go wrong with that tool.
    Jun 2010
    81
    We use them and they work great. Here's what the code looks like if you need feed & speed info. Also, we loaded the tool backwards like the picture shows so we could use the Sub Spindle to hold the part for support. The tool engages at Z2.750 and stops at Z.750. I think we ran 175 parts on the order with the same rollers. We're getting ready to run a 6,000 piece order and each part has a 2 inch long knurl. We'll see how they work in full production to get better data.
    Good Luck
    (O.D. STRADDLE KNURL TOOL 4)
    T0400
    G50 W-0.5
    M97 M87
    G97 M3 S1 = 600
    M97 M87
    G98
    G0 Z2.75 T04
    G01 Y2.75 F100.0
    X-1.600
    G01 Y1.375 F75.0
    Z0.9 F12.0
    G01 Y2.75 F75.0
    G00 X3.0
    G50 W0.5
    G97 S1 = 1000
    G0 Z3.4593 T0
    G99
    Oct 2007
    45
    Here is a knurl I Just did in a manual chucker lathe using the GenSwiss straddle knurl.
    The holder and dies were fed axially onto the preturned blank stock at as constant of a feed as my imperfect human muscles can do. As you can see, it has perfect tracking. Imagine how clean the knurls will be with a precision CNC control in the drivers seat.
    Send your application to [email protected] and we'll help steer you in the right direction.
    Oct 2007
    45
    Updated video showing the Swiss Straddle Knurling holder in an actual production setting: YouTube - CNC Swiss Lathe Straddle Knurling Demonstration - GenSwiss
    Aug 2007
    105
    Not to beat a dead horse, but I use one all the time, and it works really really well.
    One nice thing about it is that it uses a screw for adjusting the diameter, so you can adjust it a tiny bit at a time. I set the wheels over a gage pin before I put it in the machine, The size of the gage pin will vary depending on the pitch of the knurls & much else, but once you have it down it's a snap to set. (For 96 DP knurls I set it .020" smaller then the *after knurl* OD of the part.)
    Also, for the 1/2" shank one (unless it's changed, i'd double check) just put a G50V.360 Right after the knurl call, this compensates for the height of the tool, and then you don't have to set it every time.
    Here is a chunk of program:
    M03S1=2000
    T0600X2.0Y-1.4(96DP DIAMOND KNURL)
    G50V.360
    G00X0T06
    G50W-.093
    G00Z2.999
    G01Y0F.04
    G01Z4.14F.012
    G01Y-1.4F.05
    G00X2.0
    G50W.093T0
    G50V-.360
    Hope that helps!
    Oh, and the holder is pretty damn bulletproof. I bent the crap out of it the first month we had it, bent it back into shape on the big arbor press, and over a year later it it still going strong.
  1. ASME 94.6 knurl specs
    By beckmach1 in forum MetalWork Discussion
    Last Post: 11-07-2008, 08:53 PM
  2. 8 mm or 3/8" shank straddle knurls??
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 05-09-2008, 11:10 PM
  3. knurl on a solid?
    By elmi in forum BobCad-Cam
    Last Post: 04-06-2008, 02:17 AM
  4. How to Properly Knurl this Part
    By Crashmaster in forum MetalWork Discussion
    Last Post: 06-11-2007, 08:23 PM
  5. knurl
    By larry53 in forum MetalWork Discussion
    Last Post: 11-14-2005, 04:08 AM
