587,832 active members*
3,502 visitors online*
Results 1 to 14 of 14
    Jan 2011
    57
    mach 3 keeps stopping
    im hopping someone can help. when i am running mach 3 the cnc stops moving, the code is still running on mach but no motor movement.
    if i shut down mach then restart the motors will run again.
    any help would be great.
    Apr 2003
    312
    It would be helpful if a bit more info was supplied.
    What version of Mach3?
    Is this a licensed copy?
    Does machine movement stop at the exact same location each occurrence?
    OR do you get further along on a cold machine and stops occur more quickly when warm?
    How about vice versa... machine goes further in the code when warm vs cold?
    More info would certainly help us help you...
    Steve
    aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
    Jan 2011
    57
    version r1.83.027
    yes it is licensed
    i havent really noticed wether it stops in the same place all the time
    i dont think it does. dosnt seem to make a difference if it has been on for a while.
    i am running windows 7 32 bit
    hope this helps if you need any more info just ask. many thanks
    Jan 2011
    57
    just an update.
    i ran the same code today when the pc was first turned on so everthing nice and cold, went through complete code without stalling. sounds like the driver board may have overheated and shut down.
    one other thing i found was when i did the original drawings i used google sketchup. when you draw a circle you have to tell it how many segments it is with a max of 999, when you convert it to run in mach3 it produces 999 codes for a circle. i think this may have had something to do with it.
    Apr 2003
    312
    With the success you had at cold startup I'm thinking the problem is NOT with Mach3... but electronics... most likely in the controller.
    These types of problems can be frustrating to hunt down... one way to eliminate Mach from the mix is to run code without having your machine on. If Mach digests your code with full runs... it can be eliminated as the source of your issue.
    Good hunting!
    Steve
    Jan 2011
    57
    i think you are right senna i have a cheap chinese controller, with the help of
    GrootWitBaas i have managed to modify the board to stop it missing steps. he also adviced me to remove the heat sink fan which seems to be the culprit (drawing to much current) been running a lot of code since with no problems. fingers crossed. by the way i have a 4" 240v fan now colling the whole board.
    Apr 2003
    312
    Quote Originally Posted by mark.a View Post
    Good deal... I'm rooting that you have vanquished the gremlin. Happy cutting!
    Steve
    Jan 2011
    57
    well the problem is still their. while running code the cutter keeps stopping tried changing the kernell speed to see if that made any difference. the only thing that happend when i changed the speed it would start again, so i dont think it is the board overheating.
    the other thing is when the axis stop moving and you try and use the jog buttons you can hear the motors jerking a little.
    all in all its starting to get irratating especially when your half way through a cut.
    May 2010
    155
    can you load mach3 on an xp machine and try it?
    Since you have a licensed version why don't you upgrade to the latest I believe its free upgrade from a licensed version.
    the latest version is Mach3Version3.042.040 and yours is woefully old..(with lots of bugs..
    If your having problems upgrading mach3
    Send a copy of your license to [email protected]
    and ask them to help..
    35538
    Quote Originally Posted by restless1 View Post
    the latest version is Mach3Version3.042.040 ............
    3.42.040 is not the latest anymore. But you can get it from the ftp site
    Have you run the drivertest, and if so, do you get a flat line?
    When the machine stops moving, open Task manager and see what the cpu load is.
    May 2010
    155
    thats what i get for looking to quickly lol..
    Jan 2011
    57
    just tried downloading that version it got about 5mb then stopped.
    i have been onto their web site they have a version Mach3 R3.043.022
    do you no if this is a full working version.
    35538
    They are all full working versions. Provided you have a license file.
    Jan 2011
    57
    thanks ger21 downloaded the latest version all installed seems to be working fine although one of the axis did stop moving while i was setting it up im hopping it was my fault. run a fair bit of code today without stalling.
    fingers crossed.
  1. Spindle not stopping
    By adaptaflex in forum Fanuc
    Last Post: 08-17-2010, 09:03 PM
  2. spindel stopping mid job
    By jessec in forum SprutCAM
    Last Post: 12-07-2009, 06:04 PM
  3. stopping?
    By nelZ in forum CamSoft Products
    Last Post: 11-07-2009, 12:00 AM
  4. VF2 keeps stopping
    By donj1 in forum Haas Mills
    Last Post: 08-12-2005, 04:09 AM
