Originally Posted by
Action-KAT
wire from pin 5 G540 to pin 4 SSR
wire from +Vdc to pin 4 SSR
wire from pin 2 SSR to VFD FOR
wire from pin 1 SSR to VFD DCM
I have been using the VFD to control my spindle prior to trying this setup all worked fine.
It appears you are using a SSR that is totally unsuitable for what you are trying to do.
If I understand it correctly, you are using a 240vac TRIAC output SSR to switch low voltage DC control.
If going with an isolated switch, you need something with a DC logic level output.
Al.
Albert E.
