603,802 active members*
3,854 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Solid Works 2007 Question
Results 1 to 3 of 3
    Jan 2004
    668
    I may need to replace my computer soon, will Ver. 2007 run without issues in Win 7, or should I have XP pro installed on the new system?.
    Jan 2004
    3154
    I would use Win7 Pro 64.
    If it doesn't work correctly, Pro has really good Win Xp emulation
    www.integratedmechanical.ca
    May 2010
    307
    Unless you plan on using it through emulation, I would avoid Windows 7.
    SW2010 is the earliest version that is supported on Win7. The earliest version I've installed is SW2009 SP4.1. The Installation Managers for earlier service packs that I have tried won't even run.
  1. Solid works
    By dnelso in forum BobCad-Cam
    Last Post: 06-02-2009, 03:38 AM
  2. Solid works!
    By LT1TRUCK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2008, 03:22 AM
  3. just got solid works
    By bearracecars in forum Solidworks
    Last Post: 08-02-2007, 05:25 AM
  4. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
