587,770 active members*
3,327 visitors online*
Results 1 to 8 of 8
    Jul 2010
    16
    Question pocket maching with long 1/2 tool
    anybody knows the best way to machine pocket with 0.3 depth ,
    I can not use any big dia tools just 1/2 dia endmill or less and from top of part to top of pocket is 4.5", I tried several way and did not work,
    tried several speed and feed and still have problem on corner,
    any idea?! thanks
    Jan 2009
    55
    try pre drilling out the corners, then with such a long tool maybe only step down .03 in depth each pass. then do 2 or more finish passes. i have had good luck with using solid carbide endmills that are long in over all length but only maybe have 1/2 inch of flute then are slightly under cut above the flute. they wont touch the walls above the pocket as much. this wont be a fast process.
    Jul 2010
    16
    Thanks,
    Quote Originally Posted by bildoo View Post
    I already did that and did not really work,
    Jan 2009
    47
    Plunge milling may help
    Write drilling/grid pattern and rough the pocket with plunge moves. The number of holes in x and y will determine the stopover, you can tweak this to be optimal. When you call the point drilling cycle and the cnc puts a spot drill and 1/2" drill in just erase the spot drill and change the drill to an end mill.
    Mar 2011
    How do i post a new Question ?
    Aug 2009
    684
    You just did...
    Mar 2011
    This is on someones posted question.
    Aug 2009
    684
    Yes I agree it's not too obvious at first glance.
    Go to bottom right of screen 'Forum Jump' and select appropriate forum for your question.
    At top left of list there should be 'New Thread' icon. Click that then type in your question.
    DP
  1. Tool holder pocket drops on its own?
    By Captdave in forum HURCO
    Last Post: 02-28-2011, 05:26 PM
  2. Looking for a suggestion for a multi-pocket-tool.
    By slashmaster in forum Benchtop Machines
    Last Post: 07-19-2009, 11:49 AM
  3. Need Tool For Maching Letters and Numbers
    By SDETERS in forum CNC Tooling
    Last Post: 04-05-2009, 01:25 AM
  4. X2 tool entry cuts edge of pocket
    By paulpounds in forum Mastercam
    Last Post: 03-24-2009, 08:01 PM
  5. Ambigious tool pocket
    By Dsny in forum Fadal
    Last Post: 04-26-2007, 01:16 PM
