588,225 active members*
4,314 visitors online*
Results 1 to 7 of 7
    Nov 2009
    164
    X2 Wiring Schematic
    Hey all... Well I've ran into an wiring issue and need some help here guys,,, Please!
    O.k. I relocated my power boxes for the mill.. The box that's mounted to the column is now located on the wall beside my cnc control panel.. I extended the motor wiring,, I labeled all my wires with frog tape @ A1/A2 etc... Well by the time i got around to wiring it all up my cheap frog tape had fell off the wires... So needles to say I NEED HELP... Does any of you guys have any decent wiring schematics on the x2 mini mill... Hech some decent pictures may even be of some help...
    I'm really bummed on this one... Not now... I almost have all the CNC stuff in place and just about ready to configure it all...
    Anybody that has some x2 wiring diagrams please post them for me please... I've look hi/lo on the web but can't find much of anything that will help me out.
    Thank You
    Stoney
    http://www.quarterscaleprostreetberetta.com/
    you should be able to hook it back up with the info here.
    Projects 3
    one of the pics shows where ac3 ac4 p1 etc. go.
    I have more pics if you need them.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2009
    164
    Thank's Hoss.. I think I'm going to need more pics of it.. A wiring diagram would be nice if you have one... I've got the motor wires extended and do believe there correct... But the tape fell off all my blue wires & fuse wires and I haven't a clue which one goes where.. I surely don't want to guess and fry my board
    Stoney
    my page has this link that has the schematic.
    Motor Controller Repair
    Hoss
    Nov 2009
    164
    Now I'm really confused.. Hoss these don't show the wire color nor the lights! I need some pics or something
    Here is what i did... I extended the motor wires, black/white/green
    Removed the supply box from the column, mounted it to the wall, drilled a hole in the side for stud to run the column grounds to, ran both green wires that was attached to the column to the stud, ran a wire from the other side of the stud to the column.. That should be good to go... But my tape fell off a few of blue wires and i don't know what goes where...
    Here's what my mess currently looks like..
    Stoney
    Attached Thumbnails Attached Thumbnails PIC_0290.JPG   PIC_0289.JPG   PIC_0287.JPG   PIC_0286.JPG
    Nov 2009
    164
    Well I do believe I've figured it out.. I obviously need a nap.. Well after taking a closer look at the board I noticed they are labeled as 1-7 P1-P2-P3 etc.. So I'm now probing each one and soldering them in place..
    I guess i need to get some shuteye..
    Here is the diagram I'm using.
    Thanks Hoss
    Stoney
    Attached Files Attached Files
    Nov 2009
    164
    Problem Solved!
    The wiring is now soldered/heat shrunk and the enclosure paint is drying. I'm going to alter this diagram a bit for those that may run into this issue, There is a loop that runs from the green/amber bulb that's not that easy to understand in this diagram... It loops from 3-4 on the negative side of the two bulbs... This allows the amber to illuminate while in fault mode..
    Woo Hoo!
    She's about ready to config now.
  1. Wiring Schematic for proLIGHT 2000 CNC BenchTop Mill
    By dbuttaro in forum Benchtop Machines
    Last Post: 10-25-2019, 10:00 AM
  2. Looking for BOSS 5/6 wiring schematic
    By dandonegan in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2006, 11:06 PM
  3. Puma 6s electric wiring schematic book
    By emergent in forum Daewoo/Doosan
    Last Post: 03-14-2006, 04:38 AM
  4. Schematic Dro...
    By Viumau in forum CNC Machine Related Electronics
    Last Post: 05-06-2005, 05:00 PM
  5. CNC router wiring schematic question.
    By CRFultz in forum CNC Machine Related Electronics
    Last Post: 11-26-2004, 06:22 PM
