Originally Posted by
LongRat
Ok let me clarify.
My number one problem is the motor arcing. This will ignite into flames with I would guess about 20 mins running. This is nothing to do with belts or bearings or anything,
This sounds to me like motor damage due to either too high rpm or more likely, high current, the arcing is a sign of comm and or coil damage.
With a DC motor, you do not get the sense of overheat until too late due to all the heat being produced by the rotor, this takes time before the heat is radiated to the stator.
When the rotor overheats, it can throw the solder on the coil/comm connections.
Al.
Albert E.
