588,311 active members*
5,307 visitors online*
Thread: Hello All
Results 1 to 5 of 5
    Apr 2008
    5
    Hello All
    HI
    I have Milling machine CNC First MCV-641 with Fanuc Power mate O
    I remove the Linear Encoders
    I want to know wich parameter I must change to get right scale
    THANKS FOR HELP
    Apr 2008
    5
    no body help!!!!!!!!!
    Mar 2008
    169
    Is not so easy you must setup cmr and dmr to setup the system in half close loop.
    need more data. CNC model servo model motor model Screew lead reduction.
    Carlos
    Apr 2008
    5
    thanks Carlos
    CNC MODEL MCV - 641
    Control name FANUC -O MD
    Servo motor model FANUC ALPHA series C6/2000 with puls coder (bilt in)
    Mar 2008
    169
    I need the axe board Fanuc Number, the motor fanuc number, servo amplifier Fanuc Number, Servorom version, lead screw, reduction between screww and servo motor. All this info is necesary for set up half loop. You have to change some wires in cnc side.
    You also need a fanuc maintenance manual.
    Carlos
