587,600 active members*
4,487 visitors online*
Results 1 to 5 of 5
    Apr 2011
    Need 3-axis CNC tabletop with servos
    Looking for tabletop CNC 3-axis complete system.
    Can anyone recommend a provider / model for a complete turnkey system CAD/CAM 3-axis system that uses SERVOS (need fast, continuous-duty reciprocation for some of the work need *min* 40 in/min, prefer up to 60) that will fit on a desktop?
    My need is immediate and I'm ready to buy from a company that can deliver the complete package (without breaking the bank) and help me get it into service.
    Feb 2007
    498
    what are you planning on cutting?aluminum,brass,wax,steel.wood?would help to know
    Mar 2010
    99
    Look at QuickCNC machines. Fastest for woodworking purposes.
    Sorry - table size avaliable only with 300x300 and 400x400mm, based on ballscrew - more precize, but allow 4-6m/min max.
    The biggest hobby CNC is groundtop 600x1000mm screwdriver system.
    Here is pic of it compared with happy customers
    It weight 250 kg, and have very strong steel rack.
    I have my own K1218 it working on gear rack, and engraving well at 30-35m/min using step motors. Quick move at 40-45m/min
    I'm dealer of this brand, but in Russia only - you will buy it with US delivery at your own risk.
    If you need any consult or help with order, I'll glad help you. Servo is possible only at gear rack systems (1200x1200mm up to 2000x4000mm)
    Pls contact me by pm.
    Apr 2011
    Reply & clarify
    Thanks for the replies, Guys!
    I'm going to be cutting everything from stainless steel and cast iron down to copper, corian and phenolic.
    The parts I'm making are simple.
    Mar 2010
    99
    Quote Originally Posted by gemstoneartist View Post
    Model i mentioned can do all of this exept steel and cast iron.
    For metalwork you need heavy body and strong guides.
    something like this:
    [nomedia="http://www.youtube.com/watch?v=XbvzQDxtPzc"]YouTube - brother CNC Milling Steel, 30 taper w/ Lyndex-Nikken holder[/nomedia]
  1. BMC 25 - Z Axis creep when servos off.
    By gthlm in forum HURCO
    Last Post: 11-30-2010, 12:56 AM
  2. 4th axis tabletop mill projects
    By LockTech in forum MetalWork Discussion
    Last Post: 12-02-2009, 06:58 PM
  3. 5 axis servos
    By mtk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-25-2008, 01:14 PM
  4. DIY-tabletop help
    By ndrew2505 in forum DIY CNC Router Table Machines
    Last Post: 10-24-2007, 02:13 AM
  5. 2 servos/steppers on 1 axis?
    By m_c in forum CNC Machine Related Electronics
    Last Post: 07-18-2004, 03:44 AM
