588,484 active members*
4,947 visitors online*
Page 1 of 3 123
Results 1 to 20 of 43
    11
    picture to engraving?
    i am fairly new to the cad/cam world and have a few questions if somebody wouldn't mind helping out. i have been seeing alot of photo to engraving articles out there lately. i understand that the photo will have to be scanned into some type of software and then converted to g-code eventually. my question is this: what software, or packages are necessary to perform this operation? how does this work, as in: scan to what type of file, convert to what type of file and then .... eventually load and run on a cnc machine?
    there seems to be, in my mind anyway, a large cloud that the photo goes into and the engraving pops out the other side. could someone put this in laymans terms, kind of an engraving for dummies format?
    thanks for the help.
    mark
    35538
    If the photo is in jpg or bmp format, you can get g-code from Mach2/3, http://www.artofcnc.ca or use something like MeshCAM, http://www.grzsoftware.com
    1880
    Ive actually been meaning to ask a similar question.
    I know there are programs to make this happen but I am curious as to how they determine what is 3d and what is flat from the photo???
    Is this something that the user has to determine and enter values or is it something better like the software determines from the shadows how far away and what the curvature is??? (doubtfull but hopefull)
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    35538
    Usually you convert the photo to grayscale, and the depth is determined by the shades of gray, with black usually being the deepest. Depending on the software, you may be able to skip the grayscale conversion. For best results, the photo's may need to be edited a bit.
    May 2004
    350
    Cool
    step #1 scan picture around 300 dpi with scanner.
    Step #2 save scan as jpg or bmp
    Step #3 edit picture as needed like removing background, lightning, removing red eye etc
    Step #4 convert jpg to a grey 8 bit pgm file using pic to pic a free program
    Step #5 get imagecarve open the pgm and sellect the size and depth of cut usually .030 works beautiful.
    Step #6 click the convert button in imagecarve
    Step #7 run g-code
    Like I say if anyone needs help with imagecarve I will be glad to help you achieve results you are looking for!
    Proof is in the pudding look at some of my pictures I have carved.
    11
    thanks aksess, that is exactly the kind of info i was looking for, straightforward and to the point. i appreciate it.
    Sep 2003
    111
    3 types of "photo engraving"
    There are three basic approaches to engraving images.
    1. Draw (engrave) outlines or contour lines from the image.
    This is sort of like tracing the things in the picture to produce a line drawing, and then running an engraving bit along those lines. VS3D can do automatic tracing (contouring) by using the image brightness levels as if they were Z heights in a topographic model. I'm not sure if other programs do that.
    2. Draw (engrave) dots or pixels from the image.
    For example, take a flat piece of aluminum with a black anodized coating. Use a pogo-stick ("peck") type of tool path with a V-bit. The depth of each "peck" is determined by the brightness of the image at that point. Each peck is spaced far enough from the other pecks such that, at least, a small amount of black remains in between. The result is that brighter pixels in the image come out as larger (brighter) dots in the engraved piece. Because a wide V-bit is used, and the depth is determined by the pixel brightness, the amount of exposed bright aluminum is larger for bright pixels. So what you end up with is what looks like (from a distance) a grainy B&W photo. VS3D can do this. I'm not sure about other programs.
    3. Carve a continuous surface based upon the image brightness levels.
    This is what is done in the VS3D Image Embossing/Carving tutorial:
    http://www.designscomputed.com/vs3d/...mg_emboss.html
    This technique is what most of the "Image Engraving" software programs do.
    Where VS3D surpasses the other programs is that VS3D has sculpting tools to modify the surface. For example, suppose you wanted to carve a picture of someone in relief, like the face on a coin. You start out with a digital photograph of the person and map image brightness to surface height. At this point, the only thing many other software programs can do is output the G-Code or whatever to cut it. But suppose the person had dark-colored hair. Because the surface comes from image brightness, their eyebrows will be sunken deep into their forehead. VS3D has the sculpting tools to allow the eyebrow areas to be lifted and blended to make the surface look better. Yes, you could use PhotoShop or whatever to "lighten" up the eyebrows before importing the image. But it can be hard to predict if the results, when converted to a relief surface, would look good or not. In VS3D, you do the sculpting on the surface, so you always see what the true 3D surface really looks like.
    PS:
    Please excuse the "hype" - I developed the VS3D software, so naturally I'm a bit biased
    Daniel Carr - President,
    Designs Computed, LLC
    Dec 2004
    1316
    dcarr,
    I am checking your link out and your software is quite impressive.
    Jason
    May 2004
    350
    VS3D looks ok what is the total machinging time and cutting speed used on the girl carving? Tool changing time included.
    Sep 2003
    111
    Quote Originally Posted by Aksess
    The piece shown was done using a 60 degree V-bit (no tool changes required). First pass was a horizontal traversal (uni-directional "climb" cut). Second pass was a vertical traversal (alternating direction). The second pass wasn't really necessary, as it turns out. The results after the first pass were good and the second pass provided only a minimal amount of cleanup.
    step-over spacing - 0.025"
    XY jog rate - 3"/sec.
    Z jog rate - 2"/sec.
    XY feed rate - 2"/sec.
    Z plunge rate - 1"/sec.
    material - MDF board
    Total time for the first pass was about 14 minutes.
    The second pass was less than that because it cut in alternating directions (much less jogging than the first pass).
    This was basically the first attempt at this piece, and the chosen speeds were probably slower than optimal.
    Nov 2005
    4
    what kind of cnc machine was used for the girl portrait ?
    Sep 2003
    111
    Quote Originally Posted by doroteo
    I have an S&W Engineering CNC machine. But the girl photo as shown carved in wood was done on a Shopbot router (the VS3D software has ShopBot output as well as G-Code).
    Jun 2005
    93
    The girl carved out is impressive. If I could though, I'd like to comment on the price. I just about lost my breathe when I saw what you are asking for it. If I was going to sell my work, it would be fairly easy to pay for it, but as a hobby or beginner......
    Nice job on simplicity.
    Sep 2003
    111
    VS3D pricing
    Quote Originally Posted by borrisl
    Thanks for your comments ...
    VS3D is currently offered at $975. I believe that it compares very favorably with other programs with similar capabilities such as Type 3 and ArtCAM Pro (which costs over $6,000).
    VS3D is one of the few Virtual-Sculpting CAD/CAM programs out there.
    If you'd like a free 30-day full-function trial of VS3D, let me know.
    May 2004
    314
    has any one had a degree of success with the photo carving portion of deskcnc? this vs3d looks great but im wondering what other software there is that does this perhaps on a lower cost level. I dont mind paying a lot for software as its a tool and I usually choose the best of those, but id like to look at some different methods before i make a choice. Id really like to find one written by an individual that would be willing to adapt the program to my unique application.
    May 2004
    68
    Erase42
    "has any one had a degree of success with the photo carving portion of deskcnc?"
    I"ve been fairly happy with DeskCnc for carving photos. I've got a few in my photo gallery....all done on deskcnc. I've also got bobcad with bobart, which cost me a bit more and doesn't seem to do any better. IMO deskcnc is a very easy program to use and relatively cheap.
    Sep 2003
    111
    Quote Originally Posted by erase42
    Custom software developed for a particular person's application is usually quite expensive. But perhaps you could describe what your application is, and I could then tell you how close VS3D is to that functionality.
    Apr 2004
    162
    I would like to add one additional program to the mix here..
    Here on the board, one of the users has begun writing a BETA program called CAMBAM that include a HeightMap feature to convert a photo to G-Code using brightness levels as a guide.
    Do a search for BAMCAM here on the site, and you will find it.. it looks really impressive so far, and is a free option to begin experimenting.
    Unfortunately, i am still searching for a free CAM program that will run fast enough to do the detail of a portrait. *IF* I ever manage to come up with the money, I would love to have MACH3, but the 100 line limit does not allow you to do a trial of this detailed an item, so i am leary of spending my money on it right now ..
    Eddie
    May 2004
    314
    Thanks for the reply, I understand that custom software is quite expensive. The nice features of yours are actually more than i need. For my application the ability to bring dark features forward would be wasted. What I need is for light and dark to be interpreted in a different way by "modulations" i guess, in the G Code. This would be software that would go hand in hand with a new product/business that im working on.
    Contact me at [email protected] if you would like some details. I imagine what I need is quite simple from programming point of view. Ive even had some thoughts that it could be done by a clever post processor.
    THanks
    Ed
    Sep 2003
    111
    There are quite a few different programs that will take an image, convert image brightness to surface height, and lay tool paths over it. However, there are fewer programs that will also show you a material-cutting preview (predicted tool grooves in surface), and even fewer still that allow you to perform free-form sculpting on that surface before cutting it. And since image brightness almost never correlates perfectly with the desired surface height, I think the sculpting tools are very important.
Page 1 of 3 123
