587,238 active members*
3,827 visitors online*
Thread: Power Supply
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Apr 2011
    First of all, I don't like seeing a variac in anything that isn't completely shielded and grounded, or enclosed in non-conductor at all times. If some little kid turns that knob when nobody is looking those rails could be running 120V next time you power it up. Somebody touches a rail then and they might as well stick their fingers in an outlet. In fact, the assumption should always be that those rails have potential 120 (or 130) on them with a variac.
    Second, your requirement is for about 20 V. You don't need continuously adjustable voltage up to 130. You don't need a transformer that puts out more than 24 V, which is a very common voltage, and considerably safer for this kind of device. The only thing you needed to find out is how many amps you needed and then to buy a 24V transformer to suit.
    So why can't you measure the amperage? Put an ammeter in series (NOT parallel) with one of your 7 heating elements. That should be well under 10 amps, so you won't blow your meter's internal fuse. Then multiply that ammeter reading by 7 to get the total amperage needed.
    Then buy a 24V (or 23.6V) transformer rated about 25% or more above your total amperage needs. You can feed it with a dimmer or router speed control on the 120V side for some adjustment range. Put a fuse in line with both the input and the output. Then sell the Variac on eBay.
  2. #22
    Mar 2011
    vtcnc,
    Thanks for reading all of the posts. I agree with your concerns, and I have two little kids, not just one.
    The variac provides not only variable power at the peak, but it is also used to "stretch" the wires pre and post cut. They are not happy about instant power. So the wife will turn it from 0 to 25, slowly, to warm up the wires, make the cut, and then slowly turn it from 25 to 0, and turn it off.
    If there is something that I can do to make the existing solution more safe, please let me know. It is fused and human controls are in place to prevent the scenario that you describe.
    At this point the unloading and the loading or the polyester ribbon takes 10 minutes, the cutting only takes less than a minute.
    She is also aware that there is voltage present and doesn't touch anything metal while cutting. It is all about the procedures used, precautions included.
    The solution is working great and she is very happy. I will time the before and after to calculate the man hours saved. But right now she is cutting nearly 500 3 foot ribbons a day into 6" sections. (that is 3500 cuts)
    I will be making a simliar one that will make 4" sections (9 wires instead of 7).
    Cheers,
    Paul
  3. #23
    Apr 2009
    7
    Power Supply
    Hi..
    Since you are using a Variac I assume you are going direct to the heater wires. If you can determine the current load that you require you can install
    a thermistor in series with one leg and this will allow you to just turn the
    unit on and off and not worry about power surges. The thermistor is a high
    resistance when cold and lets the power come on gradually. Once it is hot the
    resistance drops and the wires will be at normal voltage. This will solve any
    problems of turning the Variac up and down all day. Search for such a component would be suppliers such as allied radio, William B Allen in New Orleans, or Newark Electronics. You can find them on Google. Important is
    the current load so you dont overload the thermistor. These components have been around for a long time and were used in early tv's to limimt the
    current when first turned on. If you need a drawing I will make one for you.
    [email protected]
  4. #24
    Apr 2011
    Sorry, but this isn't just for you but for others who may read this thread.
    A variac without an isolation transformer is the wrong thing to use for this application, period.
    20 or so volts which you've specified can be obtained much cheaper and more easily and much more safely with an ordinary step down power transformer that isolates the 20V side from the line side. These are available surplus at half to a third the cost of what you've paid, depending on the amperage needed.
    But also, as pointed out by others, your lack of determination of the amperage draw in the first place may mean you are over spec on current with this Variac, which is another safety problem. Why haven't you measured the amperage draw of one element. You apparently have a 10 amp meter, which should be enough. Unless your running 70 amps through that Variac!
    Anybody who touches the element supply voltage side of this cutting rig is connected to line -- hopefully to neutral, and not to hot. Lets hope nobody in the next twenty years plugs it into a mis-wired outlet.
    The fact that you need to ramp up power to start could have been handled by a properly rated dimmer or router speed controller on the primary side of a normal power transformer.
    Unlike a Variac, the supply side current of a step down transformer is a fraction of the secondary amperage, approximately proportional to the step down ratio. A Variac puts the same amperage through the high side as the output. In fact they're connected together. People keep trying to tell you this.
    The fact that you didn't test amp draw with your earlier attempt with the first power transformer you tried (and burned out) should have been a warning not to just smoke test unknown circuit requirements, but actually plan the design of what is in reality a basically simple low voltage hot wire cutter power supply. This stuff is basic.
    Measure your current at the very least if you are going to hang on to this design, and make sure the Variac is rated for it. Let us know what that is, and I'll find you a power transformer rated for the current online, then make your decision about whether to continue this way -- fair enough?
  5. #25
    Dec 2003
    24223
    As the previous post and as I suggested back in post #5 to just use the Variac to determine the voltage you need, you could put a 120/120 isolation transformer between the mains and the Variac.
    But the preferred method would be a low voltage transformer, if you buy a toroidal type that is very close, then these are very easy to tailor to the exact voltage by adding or subtracting a couple of turns, usually ~2 turns/volt.
    There is a guy on ebay that makes them, Company AnTek his ebay name is Jonango.
    Al.
    Al.
    Albert E.
  6. #26
    Apr 2011
    Al.
    Al.
    An isolation transformer of sufficient amperage is probably going to cost more than a proper power transformer in the first place. He wants/needs a variable supply so adjusting turns of a toroid is unnecessary. Just get a standard 24 V power transformer and put a Harbor Freight router speed controller on the input. They are enclosed, fused, have an on/off switch and a 3 prong plug and cord already wired in. What could be simpler and less expensive?
  7. #27
    Apr 2011
    Okay, if you want to hang onto that Variac, here's a suggestion:
    1.) measure the amperage draw of your device.
    2.) if under 10 amps, go here:
    http://cgi.ebay.com/TRANSFORMER-24V-...item1e629e9e41
    3.) Hook the primary (input) of that transformer on the output of your Variac. Hook the output of the new transformer to the cutter.
    This will do three things:
    a.) reduce the load on your Variac to 2 amps or less
    b.) isolate your cutter from line
    c.) limit the maximum voltage to the cutter to about 30 volts
    You will find that now you're running near the upper end of the variac adjustment instead of the lower end, but that's fine, you should still have enough range -- with the specs you indicated earlier of about 20 volts working.
    Cheap insurance at the price.
  8. #28
    Mar 2011
    Thank you
    vtcnc, I didn't take anything personal, you are absolutly right.
    I tried measuring the amps, the MM was inline with the white wire attached to the unit (between the variac and the invention), but it didn't appear to register one way or the other, though the nichrome wires were heating up. (Not sure what the problem was.)
    She normally runs at about 36 volts, when I pushed it to 48 volts (the wires got really hot) and the 4 amp fuse on the variac blew, which makes me think that the current limit is about at 4 amps. So a transformer of 30-40 volts and 4-6 amps should work just fine. Please recommend something.
    I'll pick one of these up as well: Router Speed Control
    Thanks for the advice. Hopefully someone someday reads all of this and saves some bucks and frustration.
    Paul
  9. #29
    Apr 2011
    Quote Originally Posted by PaulEsch View Post
    vtcnc, So a transformer of 30-40 volts and 4-6 amps should work just fine. Please recommend something.
    Need Help! Power Supply - CNCzone.com-The Largest Machinist Community on the net!
    Paul
    Paul that transformer in the the ebay URL of that last post of mine is a 10 amp transformer, and it has an on-off switch and cord receptacle built into the frame. Only 20 bucks and the guy ships out fast -- I nabbed one myself this week and it came in just a few days. It checked out at 28 volts open circuit. (If you need more volts you could rectify it with a bridge rectifier and capacitor and it would probably put out about 35 volts DC. But I bet it's enough for your purposes as-is at about 24-28 V AC.)
    BTW, I'm rectifying mine with another 10 bucks worth of ebay parts because my CNC foamcutter requires DC, not AC for heat control -- I don't need the extra volts, but the CNC board will cut the 35 V down to whatever is needed.
    I can help if you need to figure out a rectifier circuit.
    If I were you I'd try it straight AC first.
    ps. I'm merely suggesting this stuff based on my own experiences and skill level -- you are on your own in terms of the safety and design of anything you build yourself. You could always hire this stuff out if you feel the need for professional wiring and design. This is a DIY user forum, so these are partial generalized suggestions only for working circuits and methods. Additional considerations like, fusing, shielding, wiring, insulating, warning labels, testing and workmanship are a builder's responsibility. I'm sure you know that but important for me to make clear in something like this.
  10. #30
    Apr 2011
    Another possibility if your cutter runs too cool with the stock transformer is to slightly increase the diameter of the cutting wire. This will cause it to draw more amps and heat up more, at a lower voltage. Don't overdo this or you will go beyond the 10 amp capacity of your transformer. Just slightly thicker wire makes a big difference in current drawn. Don't do anything extreme like doubling the thickness -- that would increase the amperage by 4 times. If you went up 40% in thickness it would double the amperage. So I'd say try to find wire about 10% thicker, and that ought to tune it for this transformer.
    Of course I mean use a slightly thicker version of the same type of wire you are using now -- don't change from nichrome to stainless steel, or vice versa, because that would alter things drastically. I'm not sure what kind and size of wire you are using now.
Page 2 of 2 12
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. controller power supply 115/230v OK for Australian power?
    By Momill in forum Australia, New Zealand Club House
    Last Post: 07-07-2011, 05:06 PM
  3. X4+ Power Supply
    By heycorey in forum Syil Products
    Last Post: 03-24-2009, 01:43 AM
  4. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
