587,626 active members*
3,448 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Trouble with Yaskawa Drive & Servo
Results 1 to 5 of 5
    May 2006
    27
    I have a Yaskawa SGDA-08 Drive and a SGM-04 Servo Motor
    I am trying to set it up, with little success.
    In Sigma Win Lite or Sigma Win+ I go to Jog mode and as soon as I turn on the servo it starts vibrating like crazy but it will jog back and forth.
    How can I get it to stop VIBRATING ?
    Please help..
    Curtis
    Dec 2003
    24220
    Not familiar with that system, but usually oscillation at stand-still is often too high gain.
    Al.
    Albert E.
    Oct 2005
    105
    Do you have the drive set up for the correct motor? You are using a 750W drive with a 400W motor. I belive there is a setting in the drive to tell it what motor you are using.
    Jul 2007
    Motion Tech Support
    If you have the full motor model numbers, it will be easier for me to assist you. The parameter Cn-02 bit 8 must be set according to the motor type that is being used. In addition, as someone stated before, we will need to tune the gains of the servo. Do you have a user's manual for this amplifier? You can always call Yaskawa Electric America at 1-800-YASKAWA (800-927-5292) then dial 22 for FREE tech support from a Motion Technical Support Engineer.
    YEATech
    Apr 2011
    CACR-PR
    overvoltage problem . can't figure out how it happen? please help. the switch is off but it shows overvoltage fault.When we switch it on the alarm is on A04 - OV...
  1. Yaskawa SGDH and SGDA servo motor/drive wiring questions
    By rpseguin in forum Servo Motors / Drives
    Last Post: 08-30-2021, 04:57 PM
  2. Yaskawa Encoder-DC Servo Motor trouble
    By nlh in forum Servo Motors / Drives
    Last Post: 11-28-2006, 03:58 PM
  3. Reconfiguring Yaskawa Drive for Position Control?
    Last Post: 11-01-2006, 02:09 AM
  4. Yaskawa AC Spindle Drive problems...blown?
    Last Post: 08-04-2006, 01:19 PM
  5. problem with Yaskawa V7 drive
    By rebrumm in forum Phase Converters
    Last Post: 05-22-2006, 10:40 PM
