587,311 active members*
3,503 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How much movement in a welded frame?
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Feb 2004
    427
    Fark, that is some frame, one of the strongest looking on the forum. Good job on getting it to 0.2mm. Nothing wrong with that. You got bits of steel everywhere. Looks like a lot of small tack welds to tie it all together. This might be the secret, a series of small low heat welds instead of bigger stitch welds or long stringer beads etc.
    Do you plan on cutting mild steel with it?
    My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
  2. #22
    Aug 2008
    77
    Quote Originally Posted by Apples View Post
    For now, mostly wood. Later on I intend on putting a 3 to 5hp spindle and flood cooling for aluminium, but will see what my 1.5hp router can do in the meantime.
    The main bed frame was built, allowing it to warp as it please. The last (top) layer of tubing on the bed and where the X bearings will bolt too were added last, taking care not to let them warp and careful measuring/clamping.
    I try to keep the welds so you can touch the weld after about 15 seconds, lots of small welds, criss cross weld pattern and go slow.
    Cheers,
  3. #23
    Feb 2004
    427
    Sounds great, just what I have been thinking of doing too. I will follow your build closely.
Page 2 of 2 12
  1. How do you simulate with welded beams?
    By bigalexe in forum Solidworks
    Last Post: 08-10-2010, 11:08 AM
  2. Some tooling I welded
    By microfusion in forum MetalWork Discussion
    Last Post: 12-31-2009, 08:08 PM
  3. Replies: 5
    Last Post: 06-19-2007, 04:31 PM
  4. Heat treating A36 MIG welded frame
    By ad_bfl in forum Mechanical Calculations/Engineering Design
    Last Post: 09-05-2006, 08:07 PM
  5. Anodizing Welded Aluminum
    By Deviant in forum MetalWork Discussion
    Last Post: 10-17-2005, 03:23 PM
