587,842 active members*
3,474 visitors online*
Results 1 to 3 of 3
    May 2011
    Looking for a 3-axis CNC for automotive
    Hello!
    Hope my fellow CNC zone members can help me out.
    Me and a couple partners are working on some automotive projects. We are building custom cars, and we do quite a bit of surfacing work.
    We can create the 3D CAD models in Solidworks, Alias, and even 3DS Max. However, we are looking to get a new, better machine.
    We are currently using an older generation of ShopBot, 24x32" table, and the Z-axis is only roughly 5-6" tall. Unfortunately, the height is a problem, we have to slice up our models into a whole bunch of pieces just to get one surface.
    *edit: i know ShopBot has that $1400 plate that can raise our Z-axis by like 8" or so, but for that additional price, I would like to compare it with another machine.
    Also, the machine is quite slow, and the vertical cuts (Z-axis) are very rough (you can see the steps). Which results in quite a bit of finishing work.
    We are currently looking for a 3-axis CNC that can produce better vertical cutting, and of course, quicker. The ShopBot seems to be great for engraving and flatter objects, but a bit weak when it comes to taller surfaces.
    Any help would be great - we dont have a specific budget yet. But we would like to keep it in the range of the ShopBots more or less.
    Thanks for all your help in advance!!!
    Sep 2006
    5
    Hey, this may help Camaster.com
    500mm Z working area
    cnc router/laser cutting and engraving machine/cnc plasma cutting machine manufacturer
    www.eternalcnc.com ; [email protected]
  1. automotive pulleys
    By subliminalitr in forum Employment Opportunity
    Last Post: 06-29-2010, 05:29 AM
  2. Automotive Rim Profile Help
    By greg hoeve in forum Mechanical Calculations/Engineering Design
    Last Post: 10-14-2008, 01:48 PM
  3. can homebuild 3 Axis CNC Mill make automotive product?
    By kustomjs in forum MetalWork Discussion
    Last Post: 12-10-2007, 06:03 AM
  4. RFQ: Automotive pulleys
    By sfr in forum Employment Opportunity
    Last Post: 11-07-2006, 05:06 PM
  5. automotive tail lights
    By turmite in forum Vacuum forming, Thermoforming etc
    Last Post: 10-27-2005, 06:22 AM
