587,216 active members*
2,936 visitors online*
    Apr 2011
    Question 112 No interupt 1998 VF3
    Thank you for the help with 234 spindle cable fault. I cleaned the connector on the spindle encoder, and the wiring harness connector. Has stopped doing that for now. When I power up the machine (VF3), after power up, say 30 secs to 1 minute, get a motor overheat, or A motor overheat, for 1/2 second then changes to 112 no interupt. This locks up the display. The second power up might be for 2-5 minutes before this happens. Then it might do it 2-4 more times, or not. Then I have run machine for 1/2 hour, to finish what ever I was doing, with no problems. Any help would be appreciated. Stephen
    Jan 2007
    107
    I am a factory tech. These alarms point me to one of two things. You will need to first check the logic voltage to the mocon pcb. You will be looking for +12 -12 +5 volts. If your voltage is good at the pcb then you have a back mocon. If you need any more info please let me know
    Oct 2009
    192
    Did you try unplugging and plugging back in the plugs on the power PCB?
    http://www.cnczone.com/forums/haas_m...dle_cable.html
    Feb 2010
    1184
    Quote Originally Posted by Haas__man View Post
    +1
  1. Wiring Optical interupt switch to BOB
    By Simon C in forum CNC Machine Related Electronics
    Last Post: 02-21-2011, 05:47 PM
  2. Optical interupt switch implementation.
    By owhite in forum CNC Machine Related Electronics
    Last Post: 07-26-2009, 10:27 PM
  3. VF-2 1998
    By wsbat in forum Haas Mills
    Last Post: 02-26-2009, 03:31 PM
  4. Please help with an optic interupt switch
    By antichip in forum CNC Machine Related Electronics
    Last Post: 09-03-2008, 03:47 AM
  5. Clock interupt or something?
    By thedoctor in forum Controller & Computer Solutions
    Last Post: 07-24-2008, 11:41 PM
