Originally Posted by
tskguy
I have been using a 1kw RC brushless motor for a while now and it works pretty darn well! My motor is 1200kv and I run it at 15volts for about 18000 max rpm with a 1:1 ratio, I also have other ratios to slow it down as needed but mostly I run at faster feeds to deal with the RPM. The biggest problem with the larger KW motors will be supplying it with 55v at 150amps!! That will be one hell of a power supply!! My 15v 80amp supply is pretty beefy and is much smaller than that monster would be. One thing I am currently working on is actually controlling the rpm through Mach3. I’m pretty close but have a few issues that I’m still trying to work out. One major issue will be getting mach3 to initialize the ESC that these motors use. I’m sure a macro in mach3 would work but I haven’t tried that yet either. Any way good luck!
Deleted reply. Dumb idea I had wouldn't work.
CarveOne
http://www.carveonecncwoodcraft.com
